OEM Vitara Piston Rings Or Aftermarket?
I'm aiming at about 300whp on my d16z6 vitara build. I'll be buying 75.5mm YCP Viatara Pistons and wanted to know if the oem rings will hold or if I should be looking for aftermarket piston rings?
Re: OEM Vitara Piston Rings Or Aftermarket?
Pretty sure most people are using Hastings or NPR rings. I think FJT includes Hastings rings in most of his kits.
Just an FYI I've got a set of 75mm vitara's and 75.5mm the 75's came with hastings, the 75.5 came with NPR the NPR look to be of much better quality.
Either way just use the rings that come with the pistons you'll be fine.
TypeRMOBBiN209
41
01-19-2011 11:57 AM
