Main's bolts chatter while torquing.
Some of my main bolts chatter while torquing them. I cleaned the bolts and the threads in the block and lube it all up with plenty of 30 weight oil and it still chatters! I was thinking that I might want to try using a tap to clean up the threads in the block. Anyone experienced this before?
Re: Main's bolts chatter while torquing.
Running a tap solved the chattering issue. I used a M11x1.5 tap. Major diameter on the bolt is about 10.8mm. The bolts felt a little on the loose side but nothing appears to have yielded. Next time i have to do this I want to find the correct tap with the right tolerances.
Now to measure the mains and get this thing running!
Or use a thread forming tap since the threads were already there. This type of tap doesn't cut metal, it just deforms it so it does not create stress risers. You should be OK on your main caps though.
