need help with Compresor map reading
Old Apr 13, 2010 | 08:20 PM
machine4321's Avatar
Default need help with Compresor map reading
I have a d16z6 all stock and i have a ihi from a t-bird turbo. this turbo is bigger then the mx6/probe but from my reading it is smaller then the t3 on the early tbirds. i did find a compressor map for it but i have no idea how to make sence of it.
Judging just from apperance this should be a great turbo for my DD needs and mabye even get near the 200whp mark.....mabye
http://www.njsr.org/pics/albums/user...ssor%20map.jpg
what do the pros think, oh and it was a freebie. And thats my budget right now
thanks
Old Apr 13, 2010 | 09:34 PM
nowtype's Avatar
Default Re: need help with Compresor map reading
That compressor map is not for that turbo. That compressor map is for a turbo barely flows 10lb/min. That means the turbo would only be suitable for someone looking to make about 100hp. Basically it belongs on a Smart Car or something like it.
The T-bird turbo has to flow at least 20lb/min. I'll let you know now, unless you have tools or friends with tools(welders, saws, ect ect ect) sometimes picking a free oddball turbo over a $150 T3 will end up costing you $300 in the end due to special parts/time/labor. I'm a big advocate of doing DIY cheap setups on $2000 cars, but at the same time, using a free turbo when every other part in the setup will have to be custom made can be costly unless you have the skills to make it work.
Old Apr 14, 2010 | 04:02 AM
\this on has a downpipe and is already bolted to an hf manifold with adapters and what not, so no more money is really needed. Thanks for the input.
i found alot of info on mx6.com as this turbo is a very popular upgrade from the prob/mx6 turbo.
If i make 180 i will be happy , if i want more ill have to save my dollards up.
thanks
B18EG6
Dec 11, 2002 03:20 PM
