Turbo install, now LIMP MODE
ok i just installed my turbo kit, and now its in limp mode. Idle's fine, and everything but when i tried to drive it around the neighborhood with the basemap i got from my local tuner, it will not let me go past 2k rpm. Car starts Jerking like crazy. I didnt try again, as soon as i left the drive way i turned around so idk if it still does this. What could it be? Could it be my injectors? i was told they were 800cc and thats what i told my local tuner they were so he put that on the basemap but i honestly dont know what size they are so i wouldnt know if it needed a resistor box or anything. Fuel pump? Anything fuel related? Distributor ignitor? help please!!
Re: Turbo install, now LIMP MODE
you need to measure the ohms resistance of the injectors. YOU NEVER install an injector without knowing everything about it . just because her 800cc doesnt tell you much. you need to know if there peak&hold or saturated. more than likely there peak&hold an dif your not running a resistor box DO NOT TURN THAT CAR BACK ON. you can and more than likely will burn out th einjector drivers
adnoh
06-10-2004 10:51 AM
