Need Answers Please!!
Old Apr 9, 2010 | 02:53 PM
smittyscivic's Avatar
Default Need Answers Please!!
OK, I have a 95 civic with a b16 fully built with t3/t4 turbo. I have the waste gate vacuum line going into the port on the turbo, i have the bov valve vacuum going to a T at the FPR valve. I have my greddy boost controller and boost gauge tied into the vacuum line at the throttle body. Now my car will hold boost just fine, tunned with EC tune at 8 psi on E85 but when i shift my BOV is making a fluttering noise, not a distinct PSHH.. My car from day one never made one noise out of the blow off, it's a constant rush of air. The guy who tuned my car said at 15 psi i was leaking air somewhere. I can't figure out why my BOV is making this noise, sounds cool but not what it's suppose to be doing. Thanks for any tips!
Old Apr 9, 2010 | 02:58 PM
tuck1crx's Avatar
Default Re: Need Answers Please!!
fully built only runnin 8psi?
Old Apr 9, 2010 | 03:04 PM
System Lord's Avatar
you have gremlins sir
Old Apr 9, 2010 | 03:09 PM
I am staying at 8 because i gotta figure out my BOV problem. It's a b16, eagle rods, je pistons, block gaurd, type r cams, rockers, ported and poslished, b16 tranny with slip. 880 precision injectors...
Old Apr 9, 2010 | 03:28 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
its called compressor surge.
get a better boost signal to the bov or check the diaphram inside it. and don't have a bad attitude or people wont want to help you.
Old Apr 9, 2010 | 03:38 PM
juz10's Avatar
people wont help you anyway.
once you figure it out on your own please post the results so that people can use the information you obtained to learn about their own build
Old Apr 9, 2010 | 04:34 PM
attack666's Avatar
My car does the same, does it damage the turbo?
Any good threads you recommend? tried searching but couldnt find threads.
Old Apr 9, 2010 | 05:19 PM
I heard it is not good. It is putting alot of stress on the turbo. I will keep working on this and let you know..
Old Apr 9, 2010 | 07:28 PM
Loved
Community Favorite
ya its hard on the turbo. turbo is spinning 15k rpms or so, and that sound is boost reversing the spin of it to spin it the other direction. it wont usually damage the turbo immediately but it is very hard on it.
look into making a better vac source for it, the best way is to dril and tap another hole with a pipe in your intake manifold and run it directly to it with a good size line. just make sure you pull the i.m. off and clean all shavings out and jb weld it to seal it. or you can buy a vac block.
Old Apr 9, 2010 | 08:28 PM
rat city rex's Avatar
What bov do you have? Do you have any under hood pictures? I $5 says you have the vac/boost line running to the bottom of the bov port. The line should run to the top of the bov.
Old Apr 10, 2010 | 03:41 PM
attack666's Avatar
please do, i just bought a new turbo and dont want any crap happening to it
what BOV you running on? Im using TURBOXS BOV.. got it used so i thought it was from the bov, but looks like i got hoses wrong or..
Old Apr 10, 2010 | 05:44 PM
Yah, i have the exact same. Chrome with the fitting on the top. Blows out the side.. I have one single hose T'd into the FPR line.. Should be enough. What i am going to do is try and make a T fitting out of the brake cylinder. I am going to run a bigger diameter hose to the BOV as well.. See if this works, if not I am going to say its the XS BOV!
Old Apr 11, 2010 | 01:50 PM
attack666's Avatar
https://honda-tech.com/forums/forced-induction-16/tial-bov-compressor-surge-2552391/
found this, now im completely lost.
Old Apr 11, 2010 | 05:14 PM
Yah, Im not sure. Tomorrow when i get off work, i am going to run a new line from the Brake cylinder and if that does not fix it, i am going to try and cut the sping like they said. I'll post it and let you know.
Old Apr 12, 2010 | 04:23 AM
attack666's Avatar
alright ill be waiting, goodluck
Old Apr 12, 2010 | 01:31 PM
So today I took out of the equation the boost controller and boost gauge. I had one line going from the manifold to the FPR with no breaks in the line. I ran a new hose from the BOV to the throttle body. I also took 2-3 rings out of the BOV and still the same. I talked to a friend and he said it could be leaking air from a coupler and that is or could be why the BOV is messing up because of a pin hole leak.. Is this possible?? I do not know.. I ran out of time working on it, so my plan is tomorrow go to the advanced and buy 4 new couplers, put them on with the same t clamps that I have and go from there.. I also bought a T and thicker hose incase i decide to T into the brake cyliner. I'm not sure if I rather do that or try to buy a new BOV and see what happens with that one. If it does the same, then Im stumped and will tap into that.. Confusing I know, but hopefully we can figure this out..
Old Apr 12, 2010 | 01:40 PM
Do you have any pics of how its setup? Show me some underhood shots
Old Apr 12, 2010 | 01:45 PM
attack666's Avatar
ah damn, alright try to post some pics now of the setup
Old Apr 12, 2010 | 05:44 PM
slowhitEJ1's Avatar
My bov stopped working because of a vacuum leak off of the IM.. When youregetting on it and making boost, that extra pressure is goin into th motor.. When you let off the gas and the TB closes, the motor is no longer receiving that extra pressure and creates a vacuum on the engine side of the TB.. This vacuum is transferred through the vac line to the top half of the BOV, which is separated from the boost side by a diafragm.. This difference in pressure causes it to open and releive the extra pressure that your turbo is still creating.. You may hve already known this, but it helped me figure out where to look when I understood how it worked... Mine ended up being a rip in the rubber inside the brake booster so instead of the vacuum pulling open the BOV, it just pulled the vacuum through the rip.. Hope this helps a little, if not sorry to waste your time
Old Apr 14, 2010 | 04:09 PM
I can't figure out how to post pictures(Jpeg) But what i did was took off all the piping for my turbo, intercooler.. I am buying 3 new coupers and i also bought new vacuum lines. I am going to buy a new bov and get a flange for it too.. I think the air is leaking from the BOV adaper pipe, it's not the 2 bolt flange. You just screw three bolts to tighten it to the piping.. I do not like this set up. So attack666 I would bet that it's the BOV.. I am not 100% sure but i have been working on this problem for over a month and am starting over with brand new piping, couplers, clamps, and a BOV.. If this does not solve my problem then i am taking it to a garage and paying someone to look at it.. I did the complete engine build from start to bottom myself so i do know alot about honda's but this vacuum problem is beating me.. Sorry i couldn't help more, but i will get you posted!
Old Apr 15, 2010 | 03:33 PM
attack666's Avatar
ah that sucks bro, hardluck!!
i currently took off my turbo kit to build my engine.. got lots of T's here and there i guess ill cancel those and take the hoses direct to the IM. if that didnt help then ill try to borrow a BOV from anyone and check before i go and buy another BOV and might still have the problem.
keep us updated !
b18vtec
Mar 4, 2009 10:17 AM
phantomsi3
Aug 30, 2008 12:03 AM
Si Shane
Nov 20, 2004 08:07 PM
kholmes
Apr 30, 2004 01:20 PM
