Problems connecting ECU
Old Apr 12, 2010 | 08:10 AM
jamesfawcett's Avatar
Default Problems connecting ECU
hi everyone,
im having problems with my ecu, i bought an ecu from a member on ebay called importworkz and cant get it to plug in,
heres my original ecu inside:
heres my ecu i was sent:
heres the two connectors with the differences circled in red:
can anyone tell me, if i cut off the tab on the plugs so it connects will it be ok?
thank you
james
Old Apr 12, 2010 | 08:44 AM
dpetro1's Avatar
Default Re: Problems connecting ECU
hmm, you are in the UK so i assume you are having a problem because you purchased a USDM ecu. i dont see why it would hurt to trim the connector to fit but first you need to confirm that the pinout is the same as obd1 usdm and jdm ecu's. i dont see why it would be different but i dont know
NickGREPSMN
May 2, 2013 04:08 PM
josh_db1
May 11, 2010 08:35 AM
Pimpsherm2009
Jan 13, 2010 06:05 PM
TehGhett0P1mp
Mar 4, 2009 09:40 PM
Sohc Driver
Nov 18, 2003 10:19 AM
