Wire tucked now where to mount soleniod?
Alright, so I did a wire tuck an a motor build in my integra. Now im getting ready to install the turbo setup, but firstly im trying to decide where to mount my AEM boost soleniod? I was thinking maybe mounting it under the dash then drill two holes in the firewall for the stainless steel lines to be ran through? Anyone have any idea's on a clean install?
Re: Wire tucked now where to mount soleniod?
The solenoid clicks when it's activated so that would probably get old pretty fast.
I mounted mine on the bar that runs down the middle of the core support that the hood release is on.If you do it on the outside of that bar you won't be able to see it on the inside of the engine bay and it's fairly easy to still.
HELLO,GOOD MORNIN'
T1 sells a bracket that is easy to use and cheap. Its the correct size and it's flat. I ran mine all the way around to the front of the car.
I checked t1racedevelopment.com an the bracket sell's for $17 dollars so I think im going to go that route. Also when you guy's mounted the soleniod where did you run the wire leads to? Don't they run inline with the wire's coming out of the AEM Tru Boost gauge? Since my bumper cover is still off I think im going to run it through the inner driver side fender just like the headlight harness was ran. If there is an easier way please chime in.
Thanks in advance.
Thanks in advance.
the soL that could
Welding / Fabrication
08-21-2011 09:12 PM
langjairicer
01-25-2010 06:53 AM
