gsr-turbo expectation?
Old Apr 11, 2010 | 10:32 PM
Snailor Built's Avatar
Default gsr-turbo expectation?
So i just put my new setup in my car and the car is now siting on 333.4 whp on 11 lbs. I want to get retuned on 30lbs the entire car will be setup for it and i was just curious what you guys think i would be at? Im hoping for way upper 500's.Im sure theres someone with a similiar setup. Ive been reading on evans-tuning dyno library and dont think its crazy. Just curious.
jdm b18c
head
had gsr cams for the original dyno will be on CTRs for the new tune on 30
supertech valvetrain
bbk ssi intake manifold
70mm tb
port and polish
oem headgasket
arp headstuds
bottom:
je 9:5.1 pistons (81.5 bore)
eagle hbeams
z10 crank girdle
stock sleeves
turbo kit:
full race t4 ram horn
gt40 turbo
3"dp
precision 600hp fmic
crome pro
1000 cc injectors
4 bar map
Old Apr 12, 2010 | 02:29 AM
95skunkedgsr's Avatar
Default Re: gsr-turbo expectation?
risky on stock sleaves if you ask me 30 psi on a gt40 is alot
Old Apr 12, 2010 | 04:08 AM
sanman000719's Avatar
agreed man I made 500@24psi with a bone stock motor on e85 with a t3/66 ran it all last summer with no issues at all
Old Apr 12, 2010 | 06:55 AM
im tryin to hit 550-575
Old Apr 12, 2010 | 09:34 AM
Schister66's Avatar
Man U FTW
You're not going to keep that setup around very long if you're trying to make that kind of power on the stock sleeves. If you want 550-575whp, sleeve the block and try again
Old May 6, 2010 | 02:21 AM
anothergsr2.0's Avatar
I had just blown up my stock bottom end in like a week
Just got done
building a block 84.5 sleeves the whole meal deal
EJ8 GSR-T
Jan 12, 2007 04:47 PM
91crxracer
Mar 27, 2006 01:42 PM
Freeltec
May 4, 2004 04:30 PM
hybrid901
Feb 10, 2003 01:28 AM
sparkz
Jul 10, 2002 08:30 PM
