tunning help with Water/Meth Injection
Old Apr 8, 2010 | 05:38 PM
eg:R's Avatar
Default tunning help with Water/Meth Injection
Need help with tuning Water/Meth Injection. When tuning the car in 3rd gear everything went fine. The Car is boosting 25lbs. Water/Meth Injection start at 8psi and full pressure at 23. when tuning on 4th gear the car seem to get flooded with the injection due to 4th gear taking longer to get to redline and will get more injection compare to 3rd gear run. Running s300.
Old Apr 8, 2010 | 07:29 PM
lyncoors's Avatar
Default Re: tunning help with Water/Meth Injection
What mix. It might be running to rich. What is you afr. Lean it out some. 4th gear is where you should be tuning
Old Apr 9, 2010 | 04:38 AM
lyncoors's Avatar
What size nozzle too
Old Apr 9, 2010 | 06:32 PM
eg:R's Avatar
i bought the kit used and im not sure on the nozzle size. i was using 100% meth. do you think that could have been the problem? im going to try 50/50 and see how that goes
Old Apr 9, 2010 | 08:26 PM
lyncoors's Avatar
A smaller nozzle and a mix would fix your issues
Old Apr 10, 2010 | 11:23 AM
eg:R's Avatar
ok i try 50/50 mix and still has the same problem. not knowing what size nozzle i have should i just get the smallest nozzle they carry?? i think that will be the 60 ml/min or which one will be best for my setup.
Old Apr 10, 2010 | 05:56 PM
lyncoors's Avatar
what hp are you at and what kit
Old Apr 11, 2010 | 02:30 PM
eg:R's Avatar
450hp range with a snow performance kit
Old Apr 11, 2010 | 04:59 PM
civic-r11's Avatar
How is your Hondata s300 running your water/methonal. I am in the process of about to put mine on my car.. and i am wanting my hondata s300 to turn it on and off.. how did you sent up yours???
Old Apr 11, 2010 | 07:06 PM
eg:R's Avatar
im using mine with the boost box. i think control by voltage to control the flow.
Old Apr 11, 2010 | 09:08 PM
ralph11sec's Avatar
did you use the voltage output of s300?
where is the nozzle located?
it should be the same in 3rd/4th gear.
Old Apr 12, 2010 | 04:20 AM
Tjabo's Avatar
What is your AFR with the methanol injecting? This is really pretty straight forward stuff if you just look at it in terms of the basics. Think Lambda for your AFRs (i.e. don't worry about the different stoich ratios for the methanol, just shoot for your basic AFR target of 11.5:1, 12:1 or whatever), and remove fuel from your EMS tune to compensate for the fuel added by your methanol injection.
As mentioned above, if richness is causing the problem, then running a mix will reduce that richness, at the same time as adding a healthy dose of detonation suppression to your setup.
If you're running rich like this, the easiest answer is to simply raise your boost level up some. The detonation resistance you've gained will help keep things safe, the richness will be reduced by the additional air, and you will make big power! ! !
As always though, keep a CLOSE eye on your plugs for any minute signs of detonation.
Old Apr 12, 2010 | 06:32 AM
eg:R's Avatar
im not using the s300 voltage output source. the nozzle is located 5-6inches before the throttlebody
which nozzle size should i be using with a 450-500hp range?
Old Apr 12, 2010 | 12:02 PM
Tjabo's Avatar
The answer is "whatever it likes." There are a lot of different ways to approach the whole thing.
Do you have any ideas what the answers might be to the AFR questions I posed above?
Old Apr 12, 2010 | 01:23 PM
welfarepc's Avatar
try using fuel trim per gear scalers to adjust the AFR in what ever gear you are bogging in.
Old Apr 13, 2010 | 04:15 PM
eg:R's Avatar
yes, we try leaning out the gas and got to a/f of 12.5 and still get a lot of missfire. the missfire start around 5500rpm and 20lbs of boost.
Old Apr 13, 2010 | 04:22 PM
eg:R's Avatar
Yes we are using the fuel trim per gear. The car is getting tune by boost by gear. The only thing I can try now is getting the correct nozzle because the one I have in the car is unknown. The kit was bought used and we just ran what ever nozzle that was in there. Can’t get contact of the guy anymore but he was running it in his 350hp turbo integra.
Tjabo's Avatar
Hmmm. . . That's surprising to me. . . I suspect the methanol injection isn't the cause of the misfires then, other than it does add a lot of liquid to the combustion chamber due to the different stoich point of the methanol.
Could it be possible that you have a spark problem then? Maybe try gapping your plugs a little tighter? What gap have you been running?
Old Apr 13, 2010 | 09:49 PM
Jaker's Avatar
I had issues with a misfire in the taller gears at around 5,000 rpm (it was pretty bad, struggled to get past those RPMs with full throttle). An MSD fixed the problem for me. It was probably a band-aid fix for a weak coil, but it did fix the issue.
Old Apr 14, 2010 | 04:42 PM
eg:R's Avatar
spark plugs are gap around 25-27mm. we did a tune without the meth and everything was ok. we just have the rich misfire with the meth.
Old Apr 14, 2010 | 04:53 PM
lyncoors's Avatar
i still think you nozzle is to big, what kind of car did it come off of,
Old Apr 14, 2010 | 04:58 PM
eg:R's Avatar
car off a integra b20bvtec that dyno around 350hp. what size nozzle will i need for my setup? i might just have to get the correct nozzle and go from there.
Old Apr 14, 2010 | 07:02 PM
Jaker's Avatar
A rich mixture is much harder for the ignition system to fire. Oh, and I hope you meant .025-.027" on the gap, otherwise that's your problem for sure.
Old Apr 14, 2010 | 07:22 PM
lyncoors's Avatar
have you tried a mix because i think that has to be the problem. with 100% meth my car felt sluggish in the higher rpms with a 11.0 afr.went with a 50/50 mix and it felt great and leaned it out to a 12.2. but this was on a 500hp srt-4. on my car now i run 4 DO2 nozzles (direct port) with a 50/50 mix with dsm 450s. (stock block ftl)
Old Apr 14, 2010 | 07:28 PM
Tjabo's Avatar
Guys, the OP said he leaned it out all the way to 12.5:1. That's pretty darn lean!
I don't know Honda ignition systems at all actually, but I suspect maybe even if his plugs were gapped at 27 thou, they may need to be a bit tighter. . .
