GSR or Si cams ?
Old Apr 26, 2010 | 05:51 AM
attack666's Avatar
Default GSR or Si cams ?
okay got a first gen b16 cams and looking for a cheap cam upgrade for my turbo setup.
i noticed everyone on honda-tech upgrades to GSR cams really didnt see anyone upgraded to Si cams.
and from my H-T search i found out that Si cams got better specs than GSR *currect me if im wrong please*
which would be better for my FI setup?
opinions are welcomed !
Integra GS-R
Int-230 dur. / 10.6mm lift
Exh-227 dur. / 9.4mm lift
Civic Si '99 Spec
Int-240 dur. / 10.7mm lift
Old Apr 26, 2010 | 07:33 AM
azandford's Avatar
Default Re: GSR or Si cams ?
i have a b16a2 and running stock cams... my tuner we could pull out some more power for cheap with gsr cams and adjustable cam gears
Old Apr 26, 2010 | 08:32 AM
boostedEF91's Avatar
gsr Cams are better than 1st and 2nd gen b16 cams. better yet go with a set of typeR cams and you'll pull more outta your setup than any other stock cam.
Old Apr 26, 2010 | 02:19 PM
EFPhilly's Avatar
I gave away my si cams and got 99 GSR cams and love them.
Old Apr 26, 2010 | 02:42 PM
miguel329's Avatar
i have a set of gsr cams if you are interested $50 plus shippin.. im upgradin to skunk 2 cams pm me if interested.
Old Apr 27, 2010 | 10:06 AM
attack666's Avatar
ITR cams are over my budget.
I see that Si cams got better specs.. or am i wrong?
Old Apr 27, 2010 | 01:09 PM
DA TeG 90's Avatar
Just get Blox B or Skunk2 tuner2 cams. Dont waste your time with anything else. GSR / ITR cams make good power but at higher boost.
Old Apr 27, 2010 | 04:26 PM
mikeymcm's Avatar
if the dude is asking which cams make better power, si or gsr, why the F&^K do people come in here tellin him to buy some 300-500 dollar ****.
He obviously is on a budget and asking about cams that are readily available to him.
Old Apr 27, 2010 | 04:29 PM
attack666's Avatar
lol thanks mikey.. i understand their point that those stage one after market cams make alot more power..but im looking for a cheap upgrade for now
anything would be better than my first gen b16 cams as their the worst cams you could find
I just want someone to explain to me.
Old Apr 27, 2010 | 04:36 PM
azandford's Avatar
my tuned said he just tuned a car that had 1st gen bseries cams and switched them over to oem gsr cams and saw a gain of about 24hp on the setup while changing nothing else other than a retune
i actually just picked up a set for hella cheap for my b16 setup hope to retune soon
Old Apr 27, 2010 | 04:41 PM
Turbo-LS's Avatar
the gsr cams are better than any b16a cams. b16b is different story but thats same as itr cams so thats self explanitory.
Old Apr 27, 2010 | 05:25 PM
ShanghaiOC's Avatar
Are you just going to upgrade the cams or are you going to do any valvetrain work? If you can hold out for a little while, I'd get better cams than the GSRs unless you're doing the work yourself than $50 isn't much to spend
Old Apr 27, 2010 | 09:15 PM
BrothaSit's Avatar
http://www.angelfire.com/az3/hondawagon/B16Aspecs.html
the 2nd gen jdm b16a cams are better than gsr cams in my opinion
Old Apr 28, 2010 | 02:30 AM
attack666's Avatar
i have just installed and ITR valvetrain today, and yeah im doing everything my self
thanks
Old Apr 28, 2010 | 02:33 AM
attack666's Avatar
true that, its 170hp jdm motor.. BUT same specs as what you guys get in your civic Si's
thats why i just wanted to double check on the cams
Old Apr 28, 2010 | 03:38 AM
Turbo-LS's Avatar
If you installed itr valvetrain then save up and get itr cams. you can find them cheap just keep digging around. you wont be dissapointed. they will far outperform the b16 and gsr cams. i got mine for 200 bucks
Old Apr 28, 2010 | 05:14 AM
Silva Bullit DC4's Avatar
Real world dyno numbers are better than any spec. sheet.
When I first went VTEC, the GSR cams worked better in my setup than the B16 cams I already had available. I saw a 19 whp increase. And I have seen it SOOO many other times on other user's cars that the GSR's outperformed the B16's. Sure, it may vary from setup to setup, but Im just speaking from MY experiences. But I have ITR's now, thoh.
Old Apr 30, 2010 | 04:44 AM
blazed973's Avatar
type r 98 spec best for boost period
Old Apr 30, 2010 | 08:08 AM
Adam_b16a's Avatar
1st gen b16 cams are the worst ones ever made. 2nd gen b16a cams are are aggressive just as the gsr cams are. The gsr cams duration is longer and keeps the valves open longer, and the lift is just a little more than b16 cams. IMO, any stock cam is better than 1st gen b16 cams that the op has.
Old Apr 30, 2010 | 04:36 PM
attack666's Avatar
^^ thanks for the info
i gave up and decided to go for GSR cams, just paid member miguel329 for the cams he offered ..
Old Apr 30, 2010 | 04:46 PM
Adam_b16a's Avatar
GSR's are a good stock cam to start with. Eventually down the road i would consider upgrading to itr or ctr cams, but for the price of gsr cams and the power they yield for boosted cars they just cant be beat.
spoolinvtec54
Aug 21, 2011 03:24 PM
Shaun
Dec 25, 2004 02:18 AM
Boostage
Feb 5, 2004 04:57 PM
SIReg9
Aug 13, 2003 03:18 PM
