10 sec. d16 Ej BUILD!!!
I'm running tuner view so i will be able to monitor temp. and other things. But wanted to keep cluster because its easier to monitor rpm and mph while on the street.
I should of done this 1st. but heres the list of parts i have for my build now!
(Motor)
D16 zc block- 75.5 ycp vitara pistons
FJ custom length rods
Acl standard bearings
machine work done block assembled!
D16y8- lighlty ported on intake side finishing rest later
supertech springs and retainers
ARP headstuds
Honda headgasket
Edelbrock int. manifold
Edelbrock 65mm tb.(want a bigger one)
Aem fuel rail
1000cc Rc's
Walboro 255 pump
-10 an Lines from tank
-8 an to tank
Drag cast manifold
Ebay wastegate
Garret 60-1 turbo
ebay bov
3'' cold side piping
2.5" hot side piping
(Need)
Cam
Fab a DP
Backdoor IC
(Drivetrain)
ebay 6 puck sprung (not keeping this)
Fidanza flywheel
Stock z6 trans open diff.
stock axles
(Suspension)
K sport 36 way
Lakewood traction bar
replacement ball joints and some bushings
(Fuel setup)
Walboro 255 intank
-10 an from tank to motor
-8 an return
Aem fuel rail
buying fuel lab regulator and -10 an inline filter
(ECU)
Neptune demon(need to buy)
Tuner view
(Rims&tires)
Lenzos 13x8 front- 25x8.7x13 Rear 15x? (skinnies)
(Motor)
ARP headstuds
Honda headgasket
Aem fuel rail
1000cc Rc's
Walboro 255 pump
-8 an to tank
Drag cast manifold
Ebay wastegate
Garret 60-1 turbo
ebay bov
(Need)
Cam
Fab a DP
Backdoor IC
(Drivetrain)
Fidanza flywheel
stock axles
(Suspension)
K sport 36 way
(Fuel setup)
Walboro 255 intank
-8 an return
Aem fuel rail
(ECU)
Tuner view
(Rims&tires)
Started depinning extra wires in my main harness! Also a little work on driver side head light harness!
pass. side
Driver side
Leftover Weighs at least 5 Lbs.
Driver side headlight harness
pass. side
Driver side
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
