Crank Breather & Break booster Question
I have a built D on boost. The other day I was talking to my buddies who also have boosted cars (not honda's). And they were talking about catch cans and crank breathers. My Crank Breather is attached to my intake manifold with a PCV valve. Is it ok to leave it like that on a boosted setup? Or am I supposed to route the crank breather vacuum line to a catch can? And am I supposed to cut my break booster line and put a PCV valve in between it and the manifold to prevent boost from going into the booster?
Re: Crank Breather & Break booster Question
the brake booster already has a check valve to prevent positive pressure. its grey and mounted on the firewall right about midway of the vac line.
as far as your catch can questions, you will have to search. there are 232785420342 threads on it, probably 2-3 right here on the first page of the FI forum. quick answer is you should remove the stock pcv and run some lines from either the valve cover or the back of the block or both
ok but then how to i setup the catch can? I have one from my valve cover breather to catch the blowby under boost. But what do I do about the crank breather?
you can route it from the opening for the 'black box' on the back of the block.
often a controversial subject, here are some points of view:
http://www.turbod16.com/viewtopic.ph...ight=pcv+turbo
jdmjeff
01-10-2008 09:07 PM
93TurboSi
08-30-2004 09:28 PM
