RCautoworks built b18c with precision 6262
1 Post
Our goal was to hit 500hp, must say we were impressed with the power this precision unit put down .
Fully built gsr block bored over to 2.0l ( golden eagle sleeves )
Blue printed, balanced bottom end
Manly turbo tuff rods
JE pistons with upgraded wrist pins
Supertech valve train
RCautoworks top mount
RCautoworks intercooler piping
RCautoworks catch can
RCautoworks downpipe
Precision 6262
Precision 6262
Re: RCautoworks built b18c with precision 6262
what psi did you make that power ? what compression is the motor, and what size exhaust housing on the turbo?
So are you content with 500 or do you plan on figuring out the ignition break-up and shooting for more ? also what fuel was this on ? sorry for all the questions btw lol
1 Post
Its also on supertech springs, retainers and valves. The block is solid, not a drip of oil, catch can barely has any oil in it after two full dyno sessions.
i got some questions for you guys. i got a b18c with turbo i just bought. previous owner said had forged rods and pistions. compression check for each cylinder was 190 why is it so low. any help will help sorry for asking dumb questions
1 Post
If compression on all four cylinders is 190, your fine. That's not low at all, you're also just looking for close between each cylinder , 15%.
not talking **** but isnt this car making low power compared to other setups at similar psi? i think i seen dyno sheet at 28psi making over 700 with same turbo?
1 Post
Car is making good power for the setup, shoot me a link to the other setup you're talking about I'm assuming it wasn't that similar.
1 Post
The customer supplied us with a gsr block and crank so that is what we used, the crank was sent out to golden eagle and assembled down there.
here is one for you
https://honda-tech.com/forums/showth...precision+6262
and i know i seen one on a street car a while back i think it was cubish car that made close to the same power but on 29 psi?
agreed. would think at that level of boost it should be way higher. i made 522 on only 20psi. 81mm with a s362 turbo, still a nice setup tho. good job
1 Post
here is one for you
i dont understand one thing.
my car made almost that on less boost and on pump mustand dyno.
gsr
block build
skunk2 valve spring retainers
here the difference iam using skunk2 tuner 2 for cams
hp 499 at 18 psi.
nice setup and good luck
gsr
block build
hp 499 at 18 psi.
Also, is it safe to go by your prices on your website?
Oh and where and who is running that dyno?
1 Post
Some read low, some read high, we know this dyno reads low for what it is, and we know what this thing is capable at the track, so all in all we're happy and the customer is happy.
I personally have the big brother (6765) and love what the turbo makes. On 17 psi we made 466 on pump gas, we could have went further but I am currently on stock sleeves and would like the car to last a little while lol.
