boosted poor mans type r bulit!?
Old Apr 15, 2010 | 03:08 AM
jibahjab'in's Avatar
Default boosted poor mans type r bulit!?
hey guys I was wondering if any one have this set up!?
how is it,n wat y'all think of it!?
need sum help!!
00'b16head with type r internals
97'gsr block bone stock
00"b16 trans
Garett t4 turbo kit
3bar map sencor
550rc injectors
255 fuel pump
38 trim tail waste gate
Old Apr 15, 2010 | 08:47 AM
Schister66's Avatar
Man U FTW
Default Re: boosted poor mans type r bulit!?
I think you're going to need to be a little more specific if you want any help. You can boost it and it will work...anything more than that will require a little thought on your end
Old Apr 16, 2010 | 02:33 PM
tttt
Old Apr 17, 2010 | 06:16 AM
spawn_616's Avatar
its fantastic!!!need more info on it,wat psi u gna run it on,tuning?fuel, as Schister66 said..it will work but need more info on wat u want to do with it
Old Apr 17, 2010 | 08:29 AM
HiProfile's Avatar
need sum help!!
00"b16 trans
Garett t4 turbo kit
3bar map sencor
550rc injectors
255 fuel pump
*T4 is way bigger than you'll want, unless it's a divided-runner manifold.
*3bar is overkill with stock internals, especially with a T4.
*550's will barely use half that pump's capabilities, same for the turbo's max output.
*38mm will be much too small for T4 setup unless you think your stock internals will take 30psi daily.
If this will be the same setup you'll use for the next 2 years or more, I'd suggest different parts that match eachother's possible output. 50trim t3/t04e turbo, 44mm gate, and a 190lph pump. The bigger pump will actually dump it's extra heat into the fuel, most people don't realize that.
The other thing you could do is trade the itr head parts for gsr parts + money, and use that cash for forged pistons and rods. I was talking to the guys at King Motorsports and they recommend GSR cams until your goals reach above 450whp.
Old May 2, 2010 | 07:30 PM
bump
Old May 11, 2010 | 11:19 PM
89zzz's Avatar
My old setup...
Golden Eagle Sleeved B18C1 81mm Bore
CP 9.5:1 Pistons
Eagle GSR Rods
Eagle Crank
B16A Head Bone Stock w/GSR cams
Walbro 255lph
Precision SC6262 Turbo
1000cc Precision Injectors
370whp@13PSI 269tq on Pump Gas
on 9psi ran 11.42@121mph on 25x8.7x13 MH slicks on Lenso's
deauboy
Mar 5, 2013 01:32 AM
sanegb16
Jan 12, 2009 07:59 AM
silver95lsboosted
Sep 18, 2007 07:02 PM
hotasscivic
Feb 21, 2004 04:40 PM
E46M3CB
May 29, 2003 10:05 AM
