oil feed line B18 turbo
I have problems with my vtec engaging.
It seems like it's not getting enough pressure to activate the vtec, because the oil feed line is on the same t-connector behind the block.
Isn't there another place where I can put my oil feed line for the turbo?
In the front of the head in the corner there is a tapped hole near the vtec solenoid. Can I use that?
Any help?
Any help?
Re: oil feed line B18 turbo
did you check if the vtec solenoid is working?if it is ddid you removed the vtec solenoid and made sure the screen is not clogged if you did then what size oil line you got going to the turbo? as far as oil feeds i would get a sandwich plate adptor from golden eagle you can't tap into the head to use it as a oil feed.
DR. ON POINT
09-19-2002 09:31 AM
