Bubbles in coolant only when revving?
Old Apr 13, 2010 | 12:49 PM
xxxmikenicexxx's Avatar
Default Bubbles in coolant only when revving?
I doubt this has anything to do with boost, but since its a boosted B18C in my DA, figured I would post here...well anyways I had issues with my overflow filling up and not going back into radiator...I replaced HG and put in a new set of ARPs to be safe. So I replace the tstat and rad fan yesterday after still having issues...I had a small coolant leak and FINALLY the overflow drained overnight. I think it was the rad cap. My question that I was leading up to, is I am bleeding the system with a Lisle funnel...when the car is idling (my idle is 1.5k lol) there is NO bubbles. When I rev the car up, high, I get a small amount of bubbles and a small "burst" of coolant...is this normal? Cavitation from WP + extra coolant being pushed because of RPMs? Or DEF HG / deck issues? Please tell me exactly what I should see in this scenario so I can properly diagnose. WHAAT EXACTLY IS NORMAL?...thanks in advance!
Old Apr 18, 2010 | 11:20 AM
dantamparacer's Avatar
Default Re: Bubbles in coolant only when revving?
my turbo gsr's cooling system is going crazy too, have you checked your intake manifold gasket under boost it might be blowing into one of the coolant passages... well thats what people were telling me to check, good luck figuring it out im about to give up on mine and send it to a shop
Old Apr 18, 2010 | 01:34 PM
drelude95's Avatar
Sounds like your head gasket is on its way out....
https://honda-tech.com/search.php?searchid=7781528
Old Apr 18, 2010 | 03:47 PM
Update: may be fixed...took it for a 1+ hour cruise and next day checked and the overflow had nothing extra and no coolant missing, save for a couple teaspoons...might have been a faulty cap after all but I will definitely know after a couple more times driving it...i really hopse that was it.
Jamie65
Honda Civic (2001 - 2005)
Feb 16, 2017 11:58 AM
krc91987
Jun 28, 2015 03:51 AM
732xghost
Dec 22, 2006 07:22 AM
mz3bo
Feb 18, 2003 02:02 PM
whagkangmakulet
Nov 21, 2001 06:19 PM
