reliability of a b18b boosted
Old Apr 25, 2010 | 08:15 PM
M ST.'s Avatar
Default reliability of a b18b boosted
I am wondering how reliable a stock b18b will be on 10 lbs of boost from a t3/t4?
Old Apr 25, 2010 | 08:55 PM
dunkXdrift831's Avatar
Default Re: reliability of a b18b boosted
as long as its on a good tune it should hold up fine.
Old Apr 25, 2010 | 09:05 PM
dcmodnight's Avatar
search buttom man!
but so far it can do a bit more, with a good tune of course.
even read on here it could go up to 14-15 lbs.
Old Apr 25, 2010 | 11:30 PM
EGhatch87's Avatar
tune is key...im on 15psi on my bone stock LS with no problems..
Old Apr 26, 2010 | 12:03 AM
cleansi's Avatar
what hp ranges is what you should be asking....
what trim?
Old Apr 26, 2010 | 04:39 PM
M ST.'s Avatar
Its actually a holset hx35 on 10 lbs of boost with cp pistons and eagle rods i believe. I do not know the h/p numbers.
Old Apr 26, 2010 | 04:48 PM
Schister66's Avatar
Man U FTW
I dont know which "T3/T4" you have, but they do vary greatly since the term is rather broad. At any rate, if you stay in the ~300whp range, use quality parts, get a good tune and keep up regular maintenance, you shouldnt have any issues. I ran a stock block GSR for 2 years on 10.5psi on a GT3255b which made 315whp/216wtq. I eventually decided to build and here I am...issues can arise spontaneously, but with proper care and forethought, you will greatly decrease the chance of anything going wrong.
Old Apr 27, 2010 | 07:21 PM
dantamparacer's Avatar
It all depends on the tune! In Florida my stock gsr put down 378 whp on 16psi and 93oct. Now in Colorado my same stock gsr puts down 379 on 11psi on 91oct.
Old Apr 28, 2010 | 06:18 AM
stinner.5's Avatar
With rods, pistons, and a good tune, 10 lbs shouldn't be a problem at all. When I was running 12 lbs on a t3 superbird turbo and stock internals my ring lands failed within a year. The car was only making 220hp and 230tq on a dynojet. My timing and fuel were a bit aggressive though. It is all in the tune.
Old Apr 28, 2010 | 08:13 AM
turbociv910's Avatar
i run 18psi on my stock b16(just head studs), makes 420whp, and i run 10s with it
Old Apr 28, 2010 | 11:20 AM
stinner.5's Avatar
How long have you been running 18psi on your stock b16?
Old Apr 28, 2010 | 12:05 PM
sc34dc4's Avatar
I've been tuned for 2 months now on my b18b. Running 12.5lbs and my headgasket just went out 2 days ago. Only making 260whp Motor only has 94,000 on it
Old Apr 28, 2010 | 01:36 PM
X2BOARD's Avatar
94K is plenty if you never changed the gasket.
I pushed a freshly rebuilt stock LS on 12psi just fine as a daily for about 2 yrs... no issues with regular maintenance. You just shouldn't ask for too much from the tune if it's going to be a daily.
Old Apr 28, 2010 | 02:50 PM
90blackcrx's Avatar
I'd check to see how healthy the motor is first, do a leak down, compression test and then be the judge.
Old Apr 28, 2010 | 03:54 PM
also if you slap a set of arp head studs in it wouldn't hurt either and they are pretty cheap. The cheapest i found were on summit racing!
Old Apr 28, 2010 | 04:58 PM
attack666's Avatar
^^ what he said, plus a good safe side tune is a must !
Old Apr 30, 2010 | 06:37 PM
ShanghaiOC's Avatar
However you look at it, what is the size of the turbo? The rings will fail within time when you boost more than 10psi. The b18b block is known for bad rod bolts. I'd keep it around 8psi unless you plan on doing some work. Reliability is key
Old May 1, 2010 | 11:17 AM
Schister66's Avatar
Man U FTW
...I say this like once a week, but PSI doesn't mean anything. If you're at 10, 12, 15, 1000 psi, its all about the power created at that pressure level. That being said, the post above mine doesn't really mean anything. The numbers listed are really just that...random numbers. There is no magical pressure number
Old May 6, 2010 | 06:54 AM
M ST.'s Avatar
thanks for the help guys
Joe-G
Jun 7, 2010 11:32 PM
Rah Rah
Jul 26, 2004 11:09 AM
94B18B1Teg
Apr 26, 2004 07:25 PM
LsTurboIntegra
Jan 7, 2004 06:46 PM
