i am boosting soon need help asap
so i am turboing my car next month or sooner
i need help to see if i am forgetting anything
parts i have:
hf manifold
hf to tdo5h adapter
td05h turbo: no shaft play
450cc injectors
resistor box
intercooler + charge piping
oil feed line
oil drain line
tapped oil pan
parts ordering soon:
digital boost gauge
wideband a/f ratio gauge
street tune my ecu from a friend
wat other parts do i need? one of my friends said that i need a apexi avc-r gauge
parts i have:
hf manifold
hf to tdo5h adapter
450cc injectors
resistor box
oil feed line
oil drain line
tapped oil pan
digital boost gauge
Re: i am boosting soon need help asap
parts i have:
hf manifold
hf to tdo5h adapter
450cc injectors
resistor box
oil feed line
oil drain line
tapped oil pan
digital boost gauge
parts i have:
hf manifold
hf to tdo5h adapter
450cc injectors
resistor box
oil feed line
oil drain line
tapped oil pan
digital boost gauge
thats everyone. currently i have a crome chip thats tuned and i am going to have the guy redo the chip or watever...should i have datalogging on the ecu/chip or watever?
might wanna look into buying a oil filter sandwich plate for the feed line...ebay will do just fine...
what are you doin about downpipe? i recommend puttin a flex pipe in along the lines..
blow off valve?..
pleanty of vacume line....
what waistgate are you gonna run?..
how many pounds are you gonna run.. you may need a 3 bar map sensor....
just a few things to keep in mind and think about.. im not too sure what your gonna be running...
good luck buddy
blow off valve?..
good luck buddy
oh ok is the sandwhich plates plastic? the one from glowshift
i think i am going to take it to a shop and let them make me one since i have no idea how to make it.
bov came with my intercooler and piping
what vaccum lines do i need? i think i have a couple
i am running the stock on from the turbo i think its 7-8: td05h 14b
3 bar map sensor? when my car gets tuned dont the guy like put it in?
just buy misc lines of vac line.. pick up some t fittings.. and if your running 12 or more pounds of boost youll need a 3 bar....
you must purchase it and put it on or they'll charge you an arma nd a leg..
your better off just buyin the glow shift one.. there perfectly fine.. its gonna be the same price to have one made
stock map sensor only reads 11.xx pounds of boost... buy a 3 bar gm off ebay...50 bucks.. allows up to like 40 pounds.. youll never have to buy one again....
but from the sounds of things i really think you should start reading up before attempt this
The Grumpiest
Read this. Helped me sort things out.
https://honda-tech.com/forums/forced-induction-16/complete-how-turbocharge-your-honda-rep-ing-hypnotik-speed-1263795/
asianeric
Northern California (Sales)
10-12-2008 09:31 PM
89efDUSTY
12-31-2007 10:25 AM
89efDUSTY
12-31-2007 10:22 AM
spoon23_JDizM AkA SpOoN20
08-14-2005 01:06 PM
