IACVs keep breaking on boost..
Old Apr 7, 2010 | 02:40 PM
turbodailydan's Avatar
Default IACVs keep breaking on boost..
ok so my IACV keeps breaking on my boosted b18 itr. (running 1.25bar boost)
i have gone through 4 of these now, they dont last longer than a week and basicly either get stuck open or stuck closed. they stop responding to the ectune adjustments.. but replace it will a new one and it works again..
took one apart and theres a little shiny silver sprung shim or something that was broken into 2, not sure if its this that keeps failing because of the boost pressure pushing the valve open with too much force than what its designed for perhaps..? i dont know..
anyone had this problem?
ive made an inch thick spacer plate to move the iacv away from the intake and made the holes in the spacer very small, to see if it reduces the pressure entering the valve, not sure if it will make any difference but theres no harm in trying..
any suggestions welcome!
Old Apr 7, 2010 | 09:55 PM
Default Re: IACVs keep breaking on boost..
morning bump (london )
Old Apr 7, 2010 | 10:59 PM
V-SPEC 1's Avatar
What intake manifold are you using?
Old Apr 8, 2010 | 04:21 AM
b18c with itr head itr intake
Old Apr 8, 2010 | 10:22 AM
hmm i must be the only guy in the world with this issue LOL
Old Apr 14, 2010 | 08:19 AM
great.. im the only guy out there with this problem?
Old Apr 14, 2010 | 10:17 AM
rash's Avatar
I know this isn't a permanent fix, but have you thought about just blocking it off, removing the idle screw, and just tightening the throttle cable a bit?
You would obviously need to remote mount the iacv somewhere and keep it plugged into the harness, otherwise you will throw a CEL. Theres also the option of tuning the IACV out of the ECU...
Old Apr 14, 2010 | 10:29 AM
hey mate
thats how it is running at the moment (idle set by throttle bodie) however the car obviously only idles when fully warmed up, not on cold starts which is very annoying as the car is a daily.
i would like to get to the bottom of this problem, as i find it strange how loads of people have turbo B-series and still run the stock IACV and have no problems.. and yet i seem to be the only one
Old Apr 14, 2010 | 10:52 AM
90sedan's Avatar
How much boost are you running? I haven't had any problems at 28psi on my d-series set-up.
Are you replaing them with used ones? Or new oem?
Old Apr 17, 2010 | 02:17 PM
Tulo's Avatar
Old Apr 17, 2010 | 06:45 PM
93supercoupe's Avatar
i dunno if it will work, i think ive seen it, but what if u put 2 fittings and run lines to it.Like mount it away from the IM? Jus throwin it out there
b20ricepower
Jul 9, 2011 09:14 AM
VaporTrail
Oct 20, 2003 05:46 PM
_Endless_
Dec 17, 2002 10:57 PM
b18tdelsol
Apr 16, 2002 04:10 PM
