is there something wrong with my car?
Old Apr 13, 2010 | 12:19 PM
oh_dam's Avatar
Default is there something wrong with my car?
i have a question for your turbo guys, my ls turbo when i tap on the gas a couple time while the car is parked, couple seconds later smoke comes out of the exhaust, is there something wrong with the car? cause the car been driving strong like a champ and still is that is the only problem with it and it gets me worry sometimes.
Old Apr 13, 2010 | 12:47 PM
azandford's Avatar
Default Re: is there something wrong with my car?
well i busted piston rings... car smoked and still drove fine for a bit
get a leakdown test down
Old Apr 13, 2010 | 05:33 PM
iamthefollower's Avatar
what color is the car smoking??
Old Apr 13, 2010 | 05:37 PM
oh_dam's Avatar
ive been driving on it for 4 weeks now like this, seem like nothing has change about the car.
its smokes white for a couple seconds then it stops
Old Apr 13, 2010 | 05:50 PM
rat city rex's Avatar
What kind of crank case/catch can setup do you have?
Old Apr 13, 2010 | 05:53 PM
go and do a leakdown test and a compression test and see where your numbers are.
Old Apr 13, 2010 | 06:04 PM
perseverance's Avatar
compression test won't tell u if ur rings are bad...only compression rings but the car seems to be running fine he says. do you have a wideband? could be ur afr? what is it tuned on?
Old Apr 13, 2010 | 06:10 PM
dc4turbo12's Avatar
is it when you just start the car or when its been idling for a couple minutes? couple also be your valve stem seals!
Old Apr 13, 2010 | 07:20 PM
madblkscientist's Avatar
Old Apr 13, 2010 | 08:47 PM
oh_dam's Avatar
im not running one, it just a stock ls boost on 5lbs. should i run one.?
ill go do the leak down test, did the compression test about 3 days ago and it was 180 across
nope i odnt have a wideband i need to invest in one lol, its got re-tune 2 days ago on crome.
when it idles, it only does it when i tap the gas couple times then about 3 seconds later the smoke come out
Old Apr 14, 2010 | 12:41 PM
did u remove the pcv vac lines buz when u go underboost it will presurize ur crank case
Old Apr 14, 2010 | 09:08 PM
Atreidies's Avatar
^ This, but with better attention to grammar.
Old Apr 14, 2010 | 10:48 PM
oh_dam's Avatar
didnt really understood what you were saying, but now i do. thanks for the advice i will try that in the morning when i wake up before i headout for school
Old Apr 14, 2010 | 11:03 PM
4 the negative ppl let me speak english
what did u do with the line comine off the valve cover that originally went to the intake? u should put a lil breather filter on that or block it off and get a catchcan system.
remove pcv vac line from the intake manifold and reroute it to a catchcan or get a catchcan kit.
when the turbo spools up it will pressurize the charge pipes and intake manifold, the crank case needs to either breathe or see negative pressure/vac
there is another alternative which involves running a vaccuum line from the pcv vavle to the turbo inlet/intake to create a vaccuum and putting a valve cover filter on the open port
Old Apr 15, 2010 | 06:05 PM
oh_dam's Avatar
i remove the pcv vac line and put a filter on the valve cover and block off the line on the intake manifold for now until i can get a catchcan.
HondaEF8R
Nov 25, 2007 06:58 PM
goose21
May 17, 2005 10:57 AM
sleepy_hatch
10
Nov 5, 2004 11:40 PM
SPOONfdEK
Jun 24, 2004 02:45 PM
Andrew 825SM
Oct 19, 2002 10:05 PM
