B16 LS Vtec Turbo
Old Nov 24, 2014 | 05:26 PM
JSB's Avatar
JSB
Default B16 LS Vtec Turbo
I'm new to this forum and I'm no expert here. I know just enough to be dangerous. Anyway, I currently have a B16 LS Vtec and I would like to know if it is possible to successfully install a turbo and drive the vehicle despite the increased compression that results from the head/block combination.
If I build the engine with forged internals, would the compression even matter or is there a way to lower the compression without having to go with the LS or GSR head?
Honestly, I would love to have a turbo build (as I have never had a turbocharged engine before) but I would rather just use what I already have.
I've searched around without much success so I am turning to the people in the forum to help me out.
Old Nov 24, 2014 | 06:00 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: B16 LS Vtec Turbo
Yes, you can turbo that motor without having to worry about the compression. You'll be limited to the same amount of power every other stock B turbo build is limited to, you'll just make better power under the boost curve.
https://honda-tech.com/forced-induct...2A%2A-1024174/
Give that a read. It has all of your basic questions answered.
Old Nov 24, 2014 | 06:43 PM
JSB's Avatar
JSB
Thank you for pointing me to some sources.
Old Nov 24, 2014 | 07:40 PM
EsotericImage's Avatar
Retired Moderator
well is it a B16 or an LSVtec?
Old Nov 25, 2014 | 02:15 AM
NotARaCist's Avatar
Given contextual clues, I believe OP has an LS/VTEC with a B16 head. Try to keep up, Eso
Old Nov 25, 2014 | 09:38 AM
Retired Moderator
this is what happens when i drink and mod
Chad0487
27
Feb 3, 2008 09:17 PM
iheartmyej8
May 25, 2007 09:47 AM
ray_christopher
Jan 15, 2006 06:45 AM
llxzxll
Oct 26, 2004 11:48 PM
