boosted d16a
Old Dec 9, 2014 | 01:38 PM
josh.davis723's Avatar
Default boosted d16a
bored blocked skunk 2 alpha rod vitria pistons torqued down right to spec on connecting rod and main bearings new head everything is new new bearings new pistons and new head no oil pressure had it to 20 psi while cranking to prime the motor and lost oil pressure this is the 4th oem oil pump from honda packed the pump with jelly still no oil pressure cant figure it out please help asap
Old Dec 9, 2014 | 07:11 PM
accordturb96's Avatar
Default Re: boosted d16a
are you sure your pressure gauge is working correctly?? and you tried starting it once you primed and nothing?
Old Dec 10, 2014 | 11:42 AM
NotARaCist's Avatar
I never narc'd on nobody!
Old Dec 10, 2014 | 12:12 PM
Originally Posted by NotARacist
not sure your lingo is much better sometimes
Old Dec 10, 2014 | 12:43 PM
NotARaCist's Avatar
Find ONE post that I've made, with anything even remotely close to the OP's absolute abortion of the English language. I dare you.
Old Dec 10, 2014 | 02:50 PM
Aw yiss, motha fukin DIY det cans.
Old Dec 10, 2014 | 05:03 PM
NotARaCist's Avatar
Still not even remotely close to the abortion that is the OP. Also, lol@comparing misc chat posts to actual tech posts. Do I need to continue flicking you around the ears, or are you ready to decode the OP's clusterfuck? You seem quite adept at it.
Old Dec 10, 2014 | 05:46 PM
well he needs to get his **** together and quit thinking the oil light is the hand of god haha Im also wondering why someone would buy 4 oem pumps and decide they're the problem?
Old Dec 10, 2014 | 05:48 PM
most likely the oil pickup tube
Old Dec 10, 2014 | 06:14 PM
NotARaCist's Avatar
Could be the pickup, could be a clogged galley, could be a few things. Getting the tank hydro'd would help with the galleys, and replacing the pickup tube would be smart. They're cheap. The oil pressure light is a dummy light. It's called that for two reasons. First off, it has two positions: "You're probably good" (somewhere between none and too much), and "you're definitely fucked" (less than none). Second off, you're a dummy if that's your only way of seeing oil pressure in a modified/high performance vehicle.
Old Dec 10, 2014 | 06:20 PM
guess we will have to see what he says
Old Dec 10, 2014 | 06:56 PM
NotARaCist's Avatar
If we can even figure it out...
Old Dec 11, 2014 | 05:16 AM
LTCxD2B's Avatar
Might be that jet that's supposed to be in the block for non vtecs
Old Dec 11, 2014 | 06:40 AM
well its gotta be dumping oil like hell haha if he has a gauge im curious if its even working
Old Mar 2, 2016 | 07:14 PM
Yes the gauge works I've been researching that the d16a Is tthe Japan zc n the oil pump is really expensive because they don't sell it in the US then I read the d16a6 oil pump with work
NickH93
Dec 18, 2014 05:32 AM
Dontoh
May 14, 2013 04:55 PM
Danza
Apr 30, 2007 10:28 AM
dmcclain
Jul 21, 2006 09:53 PM
Midwest Auto Salon
Jul 14, 2005 05:09 PM
