Boosted eg hatch code 22 after 5k rpm
Old 11-04-2014, 06:35 PM
NC_jdmeg's Avatar
Default Boosted eg hatch code 22 after 5k rpm
I was throwing code 22 for vtec oil pressure switch, the plug broke off of it in motor swap, anyway did the wire between a4 and d6 and made the code go away but going down the road after 5k it pops cel when vtec should kick on and puts car in limp mode, turn car off and back on cel is gone, any idea how to stop this? Should I unplug vtec solenoid too?
Old 11-04-2014, 06:43 PM
Former User's Avatar
Default re: Boosted eg hatch code 22 after 5k rpm
Pull the code.
Old 11-05-2014, 08:52 AM
NC_jdmeg's Avatar
Evetytime I turn the ignition switch the code is gone
Old 11-05-2014, 08:54 AM
Click the Codes link in my signature. The solution is to leave the engine running.
What engine?
Old 11-05-2014, 11:36 AM
NC_jdmeg's Avatar
D15b vtec its the map code need a new 3 bar I guess
Old 11-05-2014, 12:21 PM
Code 3 or 5?
Old 11-05-2014, 03:08 PM
92ehatch's Avatar
If the code disappears after engine shut off it may mean a blown 7.5 amp backup fuse under the hood.
If you swapped the engine in to a car with the map sensor harness mounted to the firewall you must use that map sensor wire and not the engine harness map connector. i think some of the dx if not all used a firewall mount.
Old 11-06-2014, 02:07 PM
NC_jdmeg's Avatar
Yea it is 3, and I had to re wire map sensor wires because it was the firewall one and it wouldnt work with the one from engine harness
Old 11-06-2014, 02:19 PM
What engine swap and ECU? If there's a MAP sensor on the throttle body, you need to use that one.
Old 11-07-2014, 05:59 PM
92ehatch's Avatar
important on engine and ecu but the chassis with firewall mounted maps must use the wiring from the original because it is attached straight to the inside wiring harness.
rather on a stock z6 (ex or si) it is attached to the engine harness
if you swap a z6 into a stock dx with firewall mounted map sensor and use the z6 engine harness plug on the map sensor it will throw a code 3 (i speak from experience)
but back to basics, without his swap/chassis info we dont know.
although he did say he had to rewire it due to the firewall mount. without further info, i would say he needs to check the wiring.
Old 11-07-2014, 06:04 PM
I never narc'd on nobody!
NotARaCist's Avatar
I'm curious why OP immediately said he needed a 3 BAR MAP sensor...is there something about this car you aren't telling us? You shouldn't need a 3 BAR.
Old 11-07-2014, 06:13 PM
I don't follow your reasoning. The firewall mounted D15B7 MAP sensor and TB mounted D16Z6 MAP sensor are pinned identically to the ECU, so the firewall wires can be used for the TB MAP sensor without throwing code 3.
From the service manual:
Old 11-08-2014, 03:42 AM
92ehatch's Avatar
Hmmm. The last swap i did (my first) the ecu would throw a code 3 when i used the engine harness but not when i used the firewall mounted harness.
I guess it is possible the wiring was broken to one ...the diagram you posted does show them merging together inside.
Looks as if i am incorrect. But still does not rule out a wiring issue for the OP. thanks ron
Op disregard my previous post (s)
Old 11-11-2014, 10:03 AM
NC_jdmeg's Avatar
Sorry yes the car is boosted, but never had this problem until recently, I pulled the motor from my old wrecked car that had firewall mounted map sensor and just re wired it for tb map, only problem I can see is map sensor finally took a crap, and need upgrade
Old 11-11-2014, 10:04 AM
NC_jdmeg's Avatar
Its a d15b vtec and ecu is p28 chipped
Old 11-11-2014, 12:03 PM
NotARaCist's Avatar
Default Re: Boosted eg hatch code 22 after 5k rpm
That's not how MAP sensors work. You don't just slap a 3 BAR on there and call it an upgrade. A larger MAP sensor requires a re-tune, and how much boost you run dictates what size MAP you run. If you're running under 13 PSI, you don't need a larger MAP, period.
rfm98crv
Honda CR-V & Element
09-02-2013 05:08 AM
Nextelbuddy
10
06-19-2005 07:24 AM
gsr2envy
11-07-2004 03:32 PM
EKtypeRhaTcH
07-09-2003 11:37 AM
Quick Reply: Boosted eg hatch code 22 after 5k rpm
