T-Bolt Clamps
Old Dec 6, 2014 | 09:22 AM
Tootsie7944's Avatar
Default T-Bolt Clamps
Hey guys - I'm in the middle of restoring my R, and in the process anything I can replace with stainless steel, I'm going to. Most T-bolt clamps are stainless, but the nut and/or bolt are not or they might be zinc plated....either way that's not what I want.
HPS makes 100% stainless (nut and bolt included) T-bolt clamps...they are $6 a piece, but worth it in my opinion. I just am bad at assessing the whole ID vs OD as far as what size I need.
I have 2.5" charge pipes. I believe I need the HPS Stainless Steel T-Bolt Clamp 2.37" - 2.68" (60mm - 68mm) for 2-1/8" inch hose Part Number: SSTC-60-68. Or the SSTC-63-71 for 2.5"-2.8". Thoughts?
Here's the link to HPS:
HPS Stainless Steel T-Bolt t bolt clamp heavy duty 2.37" 2.68" 60mm 68mm
EDIT::
Hey guys, it does say they are 100% stainless...bolt and nut also. Sorry I should have posted this link originally.
http://www.hps-siliconehoses.com/hps...se-clamps.html
Old Dec 6, 2014 | 04:54 PM
accordturb96's Avatar
Default Re: T-Bolt Clamps
well becareful because it does not directly say the hardware is stainless as well. Might be a marketing gimic. If your tubes are 2.5 then you need the 2.38-2.68 clamps as 2.5 is in the middle of the adjustable range. I would order from this place if you discover they arent truly stainless as these are cheaper.
Hose Clamp
Old Dec 7, 2014 | 06:17 AM
F22Master's Avatar
Not sure where you got the rest of your stainless stuff from, but if you didn't get it from Mcmaster carr, you paid too much! lol
And they might have true full stainless t bolt clamps. Mayne labeled under food grade or something.
Old Dec 7, 2014 | 06:22 AM
F22Master's Avatar
http://www.mcmaster.com/#bolt-clamps/=ux57v0
Bingo!
Old Dec 7, 2014 | 08:44 AM
Bingo!
how are these cheaper? Im seeing $8-$15
Old Dec 7, 2014 | 08:49 AM
do you mean they're the cheapest full stainless kits you can get?
Old Dec 7, 2014 | 08:14 PM
F22Master's Avatar
Im not saying they're cheaper, but they are 100% full stainless. And they are probably a much higher quality than the $6 ones you posted... which probably arent really full stainless
Old Dec 8, 2014 | 06:42 AM
mine were about $2.50 but im sure not full stainless
Old Dec 8, 2014 | 09:48 AM
hps stainless steel t bolt clamp t-bolt heavy duty clamps
Old Dec 8, 2014 | 12:40 PM
makes sense now haha I mean ive had my intercooler on the car for awhile and dont have any issues with the ones under the hood. The ones bolted to the IC in the front of the car are rusting but even then its minimal
Old Dec 10, 2014 | 02:40 AM
IN VTEC's Avatar
I'd measure and go by the OD of the coupler...assuming you have them on the joint in question.
Most silicone couplers are 3-5mm wall thickness and can add about 6-10mm (~1/4" to 3/8") to the diameter.
turbotime
Welding / Fabrication
Apr 15, 2006 09:09 PM
StolenTeg
12
Nov 22, 2005 06:45 PM
GSC Motorsports
Jul 25, 2005 12:02 PM
Turbo-charged
Apr 22, 2005 09:11 PM
