Blue smoke issue
Blue smoke issue
Ok, so the car smokes at idle, on deceleration and when I shift gears. Doesn't smoke when I accelerate. It has a loose set up, The piston to cylinder wall clearance is .05 looser than oem so it's supposed to smoke when it's cold but not when warmed up. Here's few pictures. You will be able to see some burn oil on hot side of the turbo under the bolt.
