Power level estimate with similiar setup?
Old Jan 8, 2015 | 08:18 PM
Kid-jdm-teggy's Avatar
Default Power level estimate with similiar setup?
I need help with my power level predictions before I get a dyno tune because I have an 11 psi wg spring and a 15 psi spring and I want to know what power each spring will make at that pressure. Reason is if I put it on the 11 psi spring during the dyno session and I didnt reach my goal, I dont want to swap spring on a hot wg that is sitting under the log top mount manifold.
Heres what Im running,
Bottom end:
B18b1
81mm bore with Nippon racing 9.1:1 pistons
Eagle H beams
Acl bearings
ARP headstud
Head:
B16A
GSR cams
Dual valve springs on IN and EX
Port polished
Turbo:
Godspeed GT35r, .70 ar compressor, .63 ar exhaust
TurboXS FMIC
Fuel:
750cc tre injectors
Walbro 255
Adjustable FPR
Using pump gas 93
Anyone with similar setups or know anyone please let me know your power level on what psi with a 35r turbo. Im trying to reach 350-400whp, Im not trying to use a mbc because I have bad experiences with them. Thanks again
Old Jan 9, 2015 | 05:45 AM
Schister66's Avatar
Man U FTW
Default Re: Power level estimate with similiar setup?
I wouldnt bother with swapping wastegate springs - go with the 11psi spring and buy a good boost controller, not some knock-off junk. I ran a Hallman MBC for years without any issues at all.
Also, if you're running a knock-off wastegate (guessing beacuse of the eBay turbo) that could be the source of your boost control issues. Manifold design also plays a role
Old Jan 9, 2015 | 06:13 AM
Dark_Teg's Avatar
If you want to just run off the gate I would go with a 15 PSI spring. It would be much safer to run the 11 psi spring with a MBC.
Old Jan 9, 2015 | 06:28 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
I second the 11lb spring.. and controller just set up a boost cut
E85B18
May 28, 2010 08:12 AM
morgan@synapse motorsport
Oct 26, 2007 09:48 AM
boostedcivicsir
Apr 11, 2007 06:34 AM
Nextelbuddy
Mar 28, 2004 08:43 PM
X2BOARD
Jun 4, 2002 08:20 AM
