DT race division vtec lock kit
Old Jan 24, 2015 | 07:00 AM
eksleeper97's Avatar
Default DT race division vtec lock kit
has anyone installed this vtec lock kit from DT race division? they use spacers instead of lock pins. can't get ahold of them to show how to install. any help would be appreciated! thanks. b series head
Old Jan 24, 2015 | 07:06 AM
B20VtecVillain's Avatar
Default Re: DT race division vtec lock kit
Pretty sure the DT kit still has lock pins.
Old Jan 24, 2015 | 08:03 AM
i just got the kit only has spacers and a vtec block off plate
Old Jan 24, 2015 | 02:51 PM
speeddave's Avatar
With their kit you'll still need to use the factory pins and add the spacer to push the pin over to engage vtec all the time.
Kits the like SF one replace all the oem components with a titanium pin. Hth
Old Jan 24, 2015 | 10:47 PM
wantboost's Avatar
Who is Mr Robot?
With stiff valvesprings you'll have tons of cam and rocker wear problems. You need a cam designed to workwith vtec being locked and run slightly softer valvesprings. Not to mention it won't idle worth a ****, will make horrible power below 6,000rpm and you need some way to tune the car, which tuning with vteclocked can be a bitch .
Old Jan 24, 2015 | 10:49 PM
wantboost's Avatar
Who is Mr Robot?
I also like SpeedFactorys kit better because it uses one piece titanium rods. No bullshit spacers that can develop play or pop out. Also the stock pins were never designed for that kind of operation and could easily break.
Old Jan 25, 2015 | 12:22 PM
Natural Aspirations's Avatar
Pop out? Have you ever had a rocker assembly apart?
So now titanium is stronger than steel?
Old Jan 25, 2015 | 02:26 PM
wantboost's Avatar
Who is Mr Robot?
I had one almost come out when an lma collapsed.
I like the idea of a one piece assembly much more.
1990_crx-si
25
Jul 30, 2009 07:31 AM
