Turbo casting
Old Oct 22, 2014 | 10:19 AM
b00st4life's Avatar
Default Turbo casting
Just doing some maintenance on my car . While checking the manifold and turbo I come across this. Name:  image.jpg
Size:  173.3 KB . I have had this turbo for 4 years and never saw this. Has this happen to anyone else. Btw it is a precision bb turbo.
Old Oct 22, 2014 | 10:39 AM
LTCxD2B's Avatar
Wow is it leaking oil or anything from there?
Old Oct 22, 2014 | 11:11 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Turbo casting
That's just a hole at the bottom of the screw hole for the oil feed... It doesn't penetrate into the oil feed bore.
If it did you'd know it because everything under the hood would be drenched in oil and the turbo would be shot.
It's common for a blind hole near a thin part of a casting to break through.
It's nothing to worry about. There's a 99.999999999% certainty that it was there out of the box, you just never noticed it.
Old Oct 22, 2014 | 11:20 AM
b00st4life's Avatar
yeah, I am not worried about it. as ^^ said, oil would have been everywhere and the turbo will be shot.
Old Oct 22, 2014 | 11:25 AM
wantboost's Avatar
Who is Mr Robot?
Yup. Even if the hole wasn't there when it was new there was still a thin spot in the casting. Over time between vibration and heat cycling that thin spot broke loose.
But that's precision for ya
EKris
Jul 22, 2008 02:09 PM
hold your breath
Feb 14, 2007 10:01 AM
nicktagz
Sep 10, 2006 07:38 PM
