which IM better? blox(itr) AEBS victor-x or other?
I collected 3 intake manifolds for my build and was hoping to test each on a dyno but I thought I would ask first maybe someone already done it
87x84.5 gsr motor stock port head pro2 cams vortech SC kit toda header 2.5 catback 70mm tb
I have blox itr style
AEBS
victor-x
from the NA section I think the aebs would be best for all motor
I keep hearing mixed results about aebs and victor-s for boosted motors. I know blox would probably loose to either of those but I have it from another motor.
or is there a chance that stock gsr dual runner would do good as well in this case?
what other manifolds that I should consider.
in the 350 max price range.
I know the skunk2 ultra racing one is good but that's way out of my budget
AEBS
victor-x
Re: which IM better? blox(itr) AEBS victor-x or other?
Ever tune that setup yet interested in the specs?, im building a fairly simple set up using a simalar SC from ATI Pro charger, im curently going to retune the setup using a entire diffrent setup using a skunk2 ultra street manifold unported for now. I would go with a manifold thats better at top end maybe even look into the ultra street manifiold, ported it makes great power and its affordable.
its gonna cost you probably same as ultra race after porting no?
why not just go with race.
its not even together yet I still need to assemble everything. just got done getting parts
im gonna tune it NA first with blox and then swap manifolds and street tune and judge by fuel demand to see which one works better for NA and later boost
I still have to make bracket for the vortech im mounting it in ac spot it got welded shaft now.
Who is Mr Robot?
Aebs and blox are both ported itr copies.
Victor x will be all top end. There is no Victor s, only a performance x which is in the same class as aebs, blox, and Skunk2
Aebs has bigger plenum volume and different length/diameter runners
Blox is almost exact replica of itr
Aebs was designed for their 2 liter race motor
Im mostly looking for dyno comparisons since all the old threads pictures are gone
Remember its with vortech supercharger not all motor
duceduce22
07-29-2005 03:34 PM
