Throttle cutting out!!
Old Nov 1, 2014 | 09:22 PM
Dirtd22psi's Avatar
Default Throttle cutting out!!
First here' the build
92 civic hatch
D16z6 turbo
fully built bottom end Eagle rods, SRP pistons bored .10 over, micro polished crank
semi built head Skunk 2 valve springs, valves and retainers, AEM cam gear, Skunk 2 intake manifold, Skunk 2 66mm throttle body
Ram horn turbo manifold, T3/T4 turbo, 3 inch DP to 3inch full SS exhaust
Greddy BOV, Hallman boost controller, Motec 3 bar map
Hondata S300 ECU, AEM Wideband O2
So the engine idles and revs fine but when I put in 1st gear and start moving and give it gas the throttle cuts out and comes back continuously, cuts out comes back cuts out and comes back.
Could it be a bad TPS
Old Nov 1, 2014 | 11:15 PM
m4xwellmurd3r's Avatar
You have s300, plug it into a laptop and see whats going on. Tps might need to be calibrated
It has been tuned properly right? No basemap bullshit?
Old Nov 2, 2014 | 03:03 AM
g2turbo's Avatar
Default Re: Throttle cutting out!!
I had the same problem on a properly tuned car. It was the TPS
Old Nov 2, 2014 | 04:39 AM
Turbo-LS's Avatar
If it's not tuned properly it'll do that. Also if tps isn't calibrated it will also jerk like that. I've also tuned a car with the tps wiring crossed it read 100% when closed and 0% fully open. While tuning we had to not completly floor the car. We were street tuning and had no tools to fix the issue.
Old Nov 2, 2014 | 06:57 AM
hon2984's Avatar
I have run ino this before as well....after changing the throttle body. There was not enough mechanical adjustment to remedy the problem by moving the sensor. thank god for hondata! Definatly is tough to drive, low rpm/low load when it starts hitting fuel cut before the throttle body is closed.
Old Nov 2, 2014 | 05:06 PM
Dirtd22psi's Avatar
what would be some good settings for my build on the TPS and TPS Ign on hondata?
Old Nov 2, 2014 | 09:14 PM
Do a tps calibration if your sensor info shows closed throttle is above 0%
Its under the tps tab I think. Theres a spot to calibrate the open and closed throttle positions
2x0
Engine Management and Tuning
11
Jun 22, 2018 08:12 PM
luckymcadam
Sep 24, 2012 07:33 AM
luckymcadam
Sep 7, 2012 02:22 PM
connor53
May 26, 2008 10:29 PM
skisuk
Dec 31, 2003 09:59 AM
