need help to identify turbo *pics*
This turbo has a stamp on it that is 'TEC" see pics
looks to be 3 inch intake side and 2.25 inch on the exhaust.
(i dont have a way to get accurate MM reading)
I am trying to figure out horsepower rating and where I may be able to get a CHRA replacement ... basically trying to get it rebuilt for cheap
any help appreciated
Re: need help to identify turbo *pics*
also has some stamps on the hot side...
"10156 03"
"S03"
"AN13"
"HT28"
looks about 5.8cm on the hot side and
7.5mm on the cold side
"10156 03"
"S03"
"AN13"
"HT28"
Man U FTW
If you can find a micrometer, that's your best bet. A standard tape measure can't get the degree of accuracy you need to make this calculation. If that's all you have, it can work, but isn't preferred.
Check out this link: Wheel Trim | Turbobygarrett
This may not help but I had a turbo rebuild done on my powerstroke back in 2004 by Jason @ Tec engineering. I know it doesn't help with turbo identification but that very well could have been rebuilt by him with a new exhaust housing hence the "TEC" stamping in the hot side. Maybe that serial # is in his system if it came from him.. Its a long shot but just a thought
Who is Mr Robot?
Well it's definitely got a t04e compressor cover and the turbine wheel is a standard Garrett "stage 3" t3 turbine wheel that's standard fare on their shelf t3/t04e turbos.
Compressor wheel could be anything so without an accurate measurementit's all speculation
Who is Mr Robot?
The turbine housing is a Volvo unit, the two humps on the turbine inlet flange are a dead giveaway. That makes me think (along with the older design compressor cover) that this is not an oem turbo but something that a company or individual put together.
What kind of power can I expect out of this turbo?
Who is Mr Robot?
No idea. Without knowing what compressor wheel it has we can't tell you. Apair if digital calipers are only like20 bucks at your local hardware/auto store. Without a pair you can't accurately measure the wheel sowe can determine what it is.
rice a roni
03-21-2013 06:12 AM
