Turbo D16Y5
hey guys, quick question. is the turbo pistons and rings from ebay a good replacement on my engine? I'm looking to boost 10-12psi, I know i need better cc and fuel pump and all that jazz but in terms of engine and its internals anyone have any suggestions?
this is what I'm talking about, wasn't sure if I could add links. Theres no reason to be rude.
YCP 75mm Vitara Pistons Low Compression Rings Honda CRX Civic D16 Turbo | eBay
If you want to talk about rude, we can talk about you. The questions you are asking are thoroughly covered in the FAQ stickies both here, as well as in the Forced Induction section. Few people have put many hours into compiling those, and making sure that the information therein would be relevant to people who wanted to learn in the future. You seem to think you're better than them. You have decided that you are too good for their information. You think you deserve your own thread, catered especially to you, with incomprehensible babble in your original post.
When you are being flat out disrespectful to some of the greatest minds on this forum, you'd better believe I'm going to marginally rude to you. Emphasis, marginally. I haven't gone full tilt yet.
Shut up, sit down, and go read. PSI means nothing. Vitara is extremely oldschool, and there are many MUCH better options out there. Figure out your goals, read everything you can get your hands on, and come back to us when you have specific questions that are not covered in the extreme multitude of information we have, freely available to you.
and i already have my turbo in, I'm just pushing 4psi so I didn't really change anything yet. I wanted more insight on higher psi, because yes it does matter obviously. to bad tough guy there is butthurt
Actually what you did was post the same thing that gets asked about a dozen times a week and expected people to hand it to you without lifting a finger. Did you at least TRY to look for your information before you posted?
This subject is one no one should be spoonfed on.
If OP expects to accomplish anything, then yeah, he might as well.
Do you even have half a clue as to what PSI means, and what it does for your engine? No, you're one of those clueless idiots who think it's just a "slap it on and forget it" bit of go-fast for your engine. No, PSI doesn't matter. PSI, on its own, means absolutely fuckall. 10-12 PSI from a T10, you might as well be pissing in your gas tank. 10-12 PSI from an HX60 would turn your motor into slag.
Go put in just the tiniest bit of effort and stop expecting us to hold your hand, or you won't be welcome in our house for long. Pro-tip: This is a house you REALLY want to be welcome in, if you're involved at all in the Honda world.
You got the only help you should have expected. Had you read, you wouldn't have needed to even post. Had to REALLY read, you would have known exactly what would happen by posting this thread. Motivate yourself, and you might just get something good out of it. Continue on this path you're on, and I give your motor 6 months, and the rest of your car a year.
