Clutch selection (Tq-capacity vs. material, surface-are and pressure)
Old 11-02-2014, 07:01 AM
mrx
mrx's Avatar
Default Clutch selection (Tq-capacity vs. material, surface-are and pressure)
Hallo,
even if not a 100% FI related topic, but i hope here are some ppl around which have experience.
I'am currently in the process of a new clutch selection. Currently i have a 6-puck Sprung Competition Stage 4 clutch. But it has a very harsh engagement which makes the car not very easy to drive. On the track it's ok, but on the road it's annoying.
I've read a bit and there are certain variables when it comes to clutches.
- Type of material
- Number of Pad's (friction area)
- Pressure applied to the disc
How did these parameters interact when it comes to Tq-capacity of a clutch in relation to clutch engagement.
Maybe someone can suggest a good clutch which has a "mostly stock engagement" and can hold up at least 300lb/ft's of engine Tq.
Thanks
Old 11-02-2014, 09:27 AM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: Clutch selection (Tq-capacity vs. material, surface-are and pressure)
For what engine?
Old 11-02-2014, 09:28 AM
mrx
mrx's Avatar
Originally Posted by NotARacist
For what engine?
B16A1 Cable clutch
Old 11-02-2014, 09:39 AM
NotARaCist's Avatar
That's...a lot of torque out of a 1.6L. I have a hard time believing that, especially since your thread in the Drag section says you have 350 WHP. Have a dyno graph to back it up? I'm not trying to be a dick - it actually does matter, especially since you want something close to OEM for driveability.
Old 11-02-2014, 09:44 AM
NotARaCist's Avatar
ACT XTSS, Clutch Masters FX300/FX350, and South Bend Clutch stage 2 "Drag Series" (part # K08017-HD-DXD) are three that are rated for 300+ torque and still have full-faced discs, but they all have very stiff pressure plates. With a more realistic torque number, I could probably find you more options.
Old 11-02-2014, 09:52 AM
mrx
mrx's Avatar
The Power/Tq numbers in my other thread are BHP, not WHP... just forgot to mention it because they are much more common in europe other then in the states.
My current state is 370bhp but thats not exactly where i want to end, so i'am searching for a clutch which has a bit of buffer left.
Old 11-02-2014, 11:00 AM
mrx
mrx's Avatar
Thanks so far, this are some options a also came across.
Just took a look for my last dyno numbers and recalc'ed them for you:
it's 321whp and 231lb/ft but as saied, there will be some more boost come next year.
Old 11-02-2014, 11:15 AM
welfarepc's Avatar
Look into a Kevlar clutch disc.
Old 11-02-2014, 11:50 AM
mrx
mrx's Avatar
Thanks, i will.
Can someone explain how the companies come up with their Tq-Ratings?
For example the ACT XTSS which is rated to 320lb/ft and it saies in the spec's that it can handle 72% over OEM, but when you look at the OEM Tq of the B18A for example and multiply that by 1,72 you come nowhere near 320lbft?!?
Just as an example, but it's a bit confusing when comparing different companies products.
Old 11-02-2014, 01:11 PM
NotARaCist's Avatar
I always ignore the % numbers. You don't test things in percentages, you test them in values. Either it holds 320 torque, or it doesn't.
DB1_559
06-23-2006 03:02 PM
SIcivicHATCH
03-19-2005 10:46 PM
2000turbosi
11-03-2003 06:20 PM
wannakno
04-03-2003 12:57 AM
bluemex
09-01-2002 09:04 PM
Quick Reply: Clutch selection (Tq-capacity vs. material, surface-are and pressure)
