from all motor to forced induction?
Old Nov 23, 2014 | 08:19 AM
H22aeghatchback's Avatar
Default from all motor to forced induction?
I have an 92 civic hatchback with an h22a cast iron sleeves cp pistons 11.5.1 comp @ standard spec h beam rods ARP head bolt main bolts Brian Crower 3 cams Brian Crower valve springs retainers port and polished head exhaust ports only stock intake stock injectors eBay 4-2-1 header and full exhaust eBay cam gears . my question is can I get lower compression pistons and put a turbo on this build or will it be more complicated ?? Thank you
Old Nov 23, 2014 | 08:33 AM
met's Avatar
met
Default Re: from all motor to forced induction?
11.5 isn't too high to boost, it comes down to a good tuner. 2v heads and 4 v head flow differently and require different compression ratios. Do some reading and research this has been covered many times. For an example a friend of mine has been boosting his s2k stock engine, 14psi with a gt30r for 5 years now. It make just under 500whp and all he uses is premium pump fuel. I believe sk2's are in the 11.3 ball park compression ratio.
Old Nov 23, 2014 | 08:58 AM
bigG's Avatar
use the proper turbo manifold and turbo and you wont have a problem on low boost (cams may be to big if they are really a stage 3 cam)
Old Nov 23, 2014 | 11:39 AM
NotARaCist's Avatar
I never narc'd on nobody!
Yep, bigger injectors, a proper turbo kit, and a good tuner should get your motor running safely wherever you want it without having to change anything in the block. 11.5:1 is great for boost.
Old Nov 23, 2014 | 01:46 PM
Thanks so its good to know I won't need lower compression pistons thanks for the info
eesupra420
Jul 16, 2011 08:00 PM
99siRACER
Jul 1, 2011 05:35 AM
spags930
Aug 21, 2009 01:52 PM
Andy Hatchback
Feb 11, 2008 07:44 AM
c1civic
Nov 5, 2003 07:00 PM
