921HP K20 PTE 6870 Mr2
1 Post
Retuned my Mr2 over the weekend with the new PTE BB 6870 turbo and here are the results. Ran out of fuel at 921hp with ID2000's and the magnafuel 4303 pump. Car weighs 2200lbs. Going to try to put this thing in the 8's this new year.
Stock sleeve K20a2
JE pistons
eagle rods
supertech valvetrain
6870 1.0 twin scroll turbo
PTE 1000 air water intercooler
Xcessive manifold
90mm throttle body
Stock sleeve K20a2
JE pistons
eagle rods
Xcessive manifold
90mm throttle body
Re: 921HP K20 PTE 6870 Mr2
Bad ***!!!
I have seen videos of this car if im not mistaken on youtube and this thing is wicked! just killing cars on the roll. Very impressive power and setup just beautiful! Love to see The K series used on diffrent non honda platforms.
A thing of beauty, no doubt!
Does anyone make an adapter to use the K with longitudinally mounted apps that isn't one off? Saw one used in an S2k, but seemed like a rare fab.
The number of midship platforms is so limited, and the bodies are a little expensive.
Want to use in Datsuns, etc.
Searched McGregor but I saw some builds and "site under construction" so I don't know if there is a place to buy them like a "shelf" item
Here is a place which plans to release them "coming soon" since last spring, maybe contact them for progress update: NITEPARTS Racing Products | Convert Motor Sports
Good luck with your search, hope you find someone to make one for a reasonable price
1 Post
Thanks for all the kind words. The car has underwent some changes. I decided to build a stronger bottom end, not because the other failed, but because i wanted more power. I also switched to a skunk2 ultra manifold. The car made the same power but with 5 lbs less boost and 2* less timing then last time. Also couldnt get it to stop spinning the 275 radial on the dyno!
K20A2
Manley turbo tuff rods +625 bolts
10.5:1 JE asymetrical pistons
L19 headstuds
CSS block
Supertech valvetrain
PTE 6870
A2w intercooler
K20A2
L19 headstuds
CSS block
PTE 6870
A2w intercooler
Dude that dyno pic. Any vids of u driving it? Gotta see it in action.
Edit: is that ur vid in ur sig? found that randomly a while back. Awesome.
Love the new SK2 manifold!
