B20v tapping noise
Old Jan 11, 2015 | 05:22 PM
Project_SOHC_EX's Avatar
Default B20v tapping noise
Fully built GS-R head Type R Cams supertec valvetrain .5mm over on in and ex BLOCK Stock B20 low compression ARP head studs...LMA's have been cleaned...Exhause journal suffered some scoring before due to wrong cam cap on reassembly-relocated the right cam cap checked head no bent valves reassembledd thought it was the high compression B20 I had went and brought the low compression new block looked to have 20-30k all bolts still retained the galvonized finish not one leak, water pipe didn't even get a chance to discolor oh and fuel rail bolt looked as new as if it came out of the factory...Head has been cleaned resurfaced hot tanked valve job valve adj...still have a tapping noise...any ideas?
Old Jan 11, 2015 | 06:44 PM
Default Re: B20v tapping noise
Rocker Arms or should I just replace the LMA's the tap is noticeable 2k to 4k or its just that i'm revving higher and the tap is less noticeable due to higher rpms?
Old Jan 11, 2015 | 10:03 PM
NotARaCist's Avatar
I never narc'd on nobody!
What clearances did you adjust your valve lash to?
Old Jan 12, 2015 | 03:17 AM
.06 and .08
Old Jan 12, 2015 | 05:53 AM
turbohatch96y7's Avatar
Originally Posted by Project_SOHC_EX
.06 and .08
should be 7 and 8
Old Jan 12, 2015 | 07:58 AM
I will try the adjustment tomorrow.at work.and thanks for the info
RMXmitch
Dec 5, 2007 03:22 PM
Dackonn
Nov 25, 2007 03:04 AM
jdmtuner012
Oct 23, 2006 06:04 PM
B20inDCinLBC
Oct 21, 2006 09:40 PM
