blocks and boost
Old Nov 28, 2014 | 06:01 AM
Rex-2000's Avatar
Default blocks and boost
which is more worth it to beef up for boost? i have a B18A and B20B i will be using a kraftwerks S/C and GSR head Hondata S300 and YTBD internals... just looking for insight on which of these two blocks would be better to build for relability
thanks in advance
Old Nov 28, 2014 | 08:31 AM
accordturb96's Avatar
Default Re: blocks and boost
both are good blocks, reliability is more dependent on how well you build it and what components you use. In the end its always a science project and a piece of metal you hope holds together haha
Old Nov 28, 2014 | 08:46 AM
Rex-2000's Avatar
i hear alot of ppl say that the B20 isnt reliable on boost or as a vtec engine how true is this?
Old Nov 28, 2014 | 08:52 AM
MishaMR's Avatar
its true,go whit b18 ...if you want to go whit b20 you need sam darton slevs! sorry for my english))
Old Nov 28, 2014 | 11:48 AM
NotARaCist's Avatar
I never narc'd on nobody!
There's nothing stopping a B20 from being reliable. Reliability is all in the quality of the build, and the quality of the tune. Run it on a basemap, and it'll **** the bed just like any other motor will.
Old Nov 29, 2014 | 06:12 AM
rudebwoy's Avatar
I love my Golden Eagle B20 block
Old Nov 29, 2014 | 10:39 AM
Boost Films SFL's Avatar
A build is as good as it's builder, tuner, driver.
Old Nov 29, 2014 | 11:25 AM
Rex-2000's Avatar
ok so has anyone had any good or bad with either block? the B18 is in the rex the B20 is in the garage, the B18 runs but runs like *** The B20 came from japan, i will not be sleeving either block (despite how much i want to) just rods bearings pistons on the bottom end
Old Nov 29, 2014 | 11:28 AM
civic-steve-94's Avatar
I have a question for this thread. Are the factory sleeves the same thickness? Or are b20 sleeves thinner because the are already 84mm from the factory?
Old Nov 29, 2014 | 11:52 AM
Rex-2000's Avatar
i constantly hear people say the B18 has seperate sleeves the B20 is a one piece and therefore awful at high rpms... but honestly i dont know who is right
Old Nov 29, 2014 | 12:21 PM
EsotericImage's Avatar
Retired Moderator
yes, the b20 is a Siamese design..
Old Nov 29, 2014 | 04:35 PM
wunfstgsr's Avatar
Loved
Community Favorite
What comp are you planing to use? that SC will like a high comp setup like for a n.a build. Sleeves to beef up the motor is ideal if you plan to boost more than say 15psi, I believe the max on that blower is around 15 psi i could be wrong but I'm pretty sure it maxes out around there. You might be able to save some money on the sleeves for something else like cams ect if you plan to boost under that, iv seen stock GSR's make around 320+ hp on about 14 psi with that SC.. Now stock for stock the LS is better it has thicker sleeves. B20 are good for the TQ but the sleeves are known to crack easier under boost.
Old Nov 30, 2014 | 04:43 AM
MishaMR's Avatar
+1 the b20 sleeves are known to crack under boost
Old Nov 30, 2014 | 07:58 AM
Rex-2000's Avatar
Not sleeping in the near future not running high comp on boost and 8 lbs of boost maybe a bit of laughing gas no more than 25 shot
Old Nov 30, 2014 | 01:20 PM
m4xwellmurd3r's Avatar
Keep the torque under 275wtq and either one should last quite a while. Im not surebhow much torque the stock b20 sleeves can take but stock b18 sleeves can handle 300wtq before they start splitting
Old Nov 30, 2014 | 08:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I have tuned quite a few Kraftwerks "B" series packages... most are stock internally and a handful have been rod and piston engines. It is likely that a CRVtec would survive long term with a conservative tune at lower boost levels. I caution you that turning down a KW kit to 8 psi would make it a bit "laggy" in the low and mid range... and peak power would certainly be lower than one would expect. Remember that boost pressure is a by-product and not a target: Your focus should be on blower speed with a specific engine displacement and redline. A purpose built engine for a KW kit would maximize your HP potential and larger displacement is another benefit.
Also, keep an eye out here (Honda-Tech, not hijacking your thread) for my own personal KW build thread... I think you will find it quite interesting.
Old Dec 1, 2014 | 02:19 AM
rudebwoy's Avatar
get the block sleeved and less worry.
Old Dec 1, 2014 | 10:43 AM
Dark_Teg's Avatar
CSS the B18 and call it a day.
Old Dec 1, 2014 | 04:03 PM
Rex-2000's Avatar
CSS? and no can do on the sleeving read previous posts and how do i find your build thread?
Old Dec 1, 2014 | 04:08 PM
NotARaCist's Avatar
CSS = Cylinder Support Systems. Think of them like a hybrid between sleeves and a block guard, just better than a guard, and cheaper than sleeves. You've only told us that you won't be sleeving, not why.
Old Dec 3, 2014 | 03:24 PM
Rex-2000's Avatar
dollah dollah bills yall
Old Dec 3, 2014 | 03:43 PM
NotARaCist's Avatar
If you can't afford $300 for a CSS, you might need to re-think your choice of hobby.
Old Dec 3, 2014 | 04:21 PM
Rex-2000's Avatar
lol where are you sleeving blocks at 300? you might want to rethink your block
Old Dec 3, 2014 | 04:33 PM
NotARaCist's Avatar
You haven't even bothered looking up CSS yet, have you?
Old Dec 3, 2014 | 04:35 PM
Rex-2000's Avatar
nope but you asked why sleeving wasnt an option... so whats with the hate? you never asked why CSS isnt an option...
mysterysktr7
Apr 23, 2009 07:51 PM
hmtcrxsir
15
Feb 6, 2009 08:01 PM
viet1337
Apr 10, 2007 09:51 PM
Tofu94
Jan 20, 2005 06:48 AM
