New Turbo Needed...Looking for 400 whp with Good Midrange. Input Needed
My old t3/t4 turbo has an 1/2" of side to side shaft play and I'd like to replace it with something that fits my new found needs.
Want I'd like to achieve:
-400 whp on 93 octane
-Good midrange power. It's a street car. I'd like to see close to 150 whp by 4000 rpms, similar to my old setup.
Specs:
-81.5 mm LS Vtec. No Sleeves. LS transmission
-Arias pistons w/ eagle rods. should yield roughly 9.4-1 compression ratio.
-Stock GSR head and Intake Manifold
-Revhard Log Manifold w
-Tial Wastegate (38mm I believe) with open dumptube
-2.5" turbo piping
-2.5" downpipe with 3" exhaust
-Precision 1000cc injectors
I've looked at countless dyno graphs. Mostly on Evans Tuning and a few on here.
Based on Evans Tuning site the GT30 turbo is used quite often with the results I'm looking for.
I also had someone recommend the Precision 5858 but i think it may deliver the power on later then I'd like.
I would like to spend around a $1000 or less but if it's well worth it I'm willing to increase my budget.
Any personal insight? I'll attach a graph of my last setup, this was done with a ls engine (same bottom end) but with a stock ls head and intake manifold. Again I would like to have similar if not better numbers down low and through the midrange but achieving 400 whp peak (or more).
Here's my old LS setup on 15 psi:
Specs:
-2.5" turbo piping
Re: New Turbo Needed...Looking for 400 whp with Good Midrange. Input Needed
3076 but at $1000 or less I know that would have to be a pre-owned unit
Also I'd personally see 3" DP and exhaust + a short ram working out better than a log with 2.5 but I know with the right amount of boost and tuning its possible, just probably a better means to get 400 with better exhaust flow for that turbo.
Who is Mr Robot?
A gt2871 would net you 400hp with about 20-30hp of wiggle room left.
Gtx2867 is another option.
A gt3071 or 3076 will do it and leave a bit more power on the table.
Personally I'd use an EFR7163. Spools about 300-400rpm faster than a 3076 at the same pressure levels, makes more midrange torque and power but is only 20hp down on the top end .
Plus the compressor flows 60lb/min at its limit.
The turbine wheel won't let you get 60lb out of the turbo but there's no reason 50-55 isn't doable
Bigmikeinteg: Good to know, I sent him a pm.
DC Legacy: I haven't seen many pre-owned units at that price level. I may consider buying new. Which size turbine A/R would you recommend for the GT3076? My downpipe has a 5 bolt flange which I may need to switch depending on the turbo. It's a tight fit at the moment (close to the radiator) but I'll make an effort to upgrade to a 3" dp. I'll look into some short ram manifolds as well.
Wantboost: I looked into the Borg Warner 7163. Price is a little more than I'd like to spend assuming I can score a used one. I did find the following however...
How about this:
Rebuilt GT3071R. I'm not sure which size turbine trim A/R this is but I'm waiting for his response. According to Garrett's website they offer a 0.64 and 0.86 A/R. Any suggestions?
http://www.ebay.com/itm/Turbocharger-genuine-Garrett-ball-bearing-turbo-GT3071R-with-billet-compressor-/181600450355?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a483af733&vxp=mtr
How about this:
Who is Mr Robot?
.86
You can't think about t3 housing sizes here since the volute is an entirely different design. Howeverin terms of overall size the .86 t25 housing is closest to a .63 t3 housing in terms of overall size and flow.
Andif you're going with a 3071 and you plan on running decent pressure levels you need a ported shroud compressorcover. The bigger t04x cover in the photo doesn't help anything. You won't make more power with it. The ported shroud t04e is more than sufficient
Man U FTW
GT3255b
Look into this ^^. I ran a gt3255b on my stock block gsr and it was a blast. Full boost by 3800rpm on an SLS miniram. Made 315whp/218wtq at 10.5psi on pump gas.
Schister's STC GT3255b stock block dyno
How about this:
Turbocharger Genuine Garrett Ball Bearing Turbo GT3071R with Billet Compressor | eBay
How about this:
.86
GT3255b
Man U FTW
I never pushed it that hard but my tuner bought the turbo from me and used it on a built LS. He made over 400whp and low 300s tq at 20-22psi IIRC (its been 5 years so its hard to recall exactly) so I know its possible
Who is Mr Robot?
what specifically are you looking at from STC? I can help you out with his stuff.
Man U FTW
Of the turbos listed on STC's site, I would choose between the GT3255b and GT3251b. You'd have to double-check with TheShodan to see if those units are still available - i know they're soon to be discontinued in lieu of their new line.
Another option is the STC Hunter
I have the gt3251b I bought from the shodan. Will be selling it soon for sure might be willing to part with it now maybe . I only put about 1k miles on it. Pm me if interested . But yeah shodan has a lot of good info to give out
I just took a look at my graph I made about 170 I think by 4.5k rpm if you want I can text you my graph . Turbo max out is about 425 whp
Who is Mr Robot?
As far as I remember TheShodan will still offer the gt32 lines and others along side his new line. If it's on the new site it's available.
Might have another avenue of marketing for STC, I can't say much more than that but if it works outit should be a promising outlet ��
Man U FTW
Yeah, you should let him know to update that.
He PM'd me a while back saying that the GT32xx series would eventually be discontinued, but I wasn't sure the exact timeline. I guess that time has passed...
