93 octane
Old Feb 12, 2014 | 05:12 PM
ROOSTER.'s Avatar
Default 93 octane
i've been looking into using a mixture to run 93 octane. i found a few different things being said ranging from :
-using a certain octane booster with a specific amount of 92 from pump
-100 octane with 91 or 92
and so on.. locally 92 is on pump. i will switch to e85 in the future but not at this time.
motor details = 81.5 wiseco pistons, 180 psi in each cylinder (dry) hp range is around 450 on neptune.
I'm just looking for some real input here on whats works well from experience. thanks in advance
Old Feb 12, 2014 | 07:53 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: 93 octane
Are you having issues at your current power level? You should be fine on that pump gas and lower horsepower level. There still isn't enough info on your setup listed to give you any real good advice.
Old Feb 15, 2014 | 05:32 AM
ROOSTER.'s Avatar
im not re-tuned yet and the car is not being driven. i will be getting the car ready for the tune very soon though and that includes filling the tank (so its a good time i ask about this.)
sorry the info was vague
as far as motor and turbo.. as follows
wiseco pistons 81.5 bore 9:1:1 compression
eagle rods
arp rod bolts
arp main studs
arp head studs
golden eagle squirter plugs
stock p72 head
gsr bottom w/gsr crank (rotating assy was balanced)
Itr cams
peakboost ramhorn manifold
silver surfer (water and oil cooled)
3in down pipe followed by 3 in thermal exhaust
aem fuel rail
holley fpr
rc 750's
walbro 255 lph pump
tial 38mm 2 bolt gate
tial bov
autoworks backdoor intercooler
Old Feb 15, 2014 | 08:58 AM
NotARaCist's Avatar
I never narc'd on nobody!
The difference between 92 and 93 octane is so minimal, if 92 is what comes out of the pump, I would just tune for 92. The added cost and effort of constantly having to deal with mixing fuels to get 93 just wouldn't be worth it, IMO.
Old Feb 15, 2014 | 02:49 PM
DO IT ON ALL FOURS
You should be able to hit 450whp with your setup and 92. If you really wanted the final say ask the guy that "designed" the turbo.
Old Feb 16, 2014 | 06:57 PM
ROOSTER.'s Avatar
well, i was just looking for input on possible ways to run a more stable pump fuel. next year i plan to switch to e85 but my budget is done for now.
thats why i was wondering about fuel additives or running a 100+92 mix or whatnot. thanks for the replies and feedback. i'll stick to 92 for now.
Old Feb 17, 2014 | 07:30 AM
gabocastano's Avatar
For every 7 gallons of 92 put one gallon of 100 and the average octane will be 93. multiply 92 times 7, then add 100 and divide by 8 gallons in total and you get 93.
Old Feb 17, 2014 | 12:41 PM
blackeg's Avatar
while im not a big fan of it, what about a small shot of meth injector for higher boost levels. it really does extend how far you can take pump gas
Old Feb 17, 2014 | 05:04 PM
ROOSTER.'s Avatar
why is it that your not a fan of it ? whats the down side ?
Old Feb 17, 2014 | 05:07 PM
ROOSTER.'s Avatar
thank you.
Old Feb 18, 2014 | 03:15 AM
blackeg's Avatar
it runs out. plus the 400ish you can make on pump gas is more than plenty for a street car. above that , use race gas above that at the track.
fanta!
Jul 6, 2005 08:13 AM
SiRkid
Jun 22, 2003 12:30 AM
Montreal R
Oct 4, 2002 02:18 PM
cccya
Jun 4, 2002 04:59 PM
gotatight92si
Oct 9, 2001 08:48 AM
