IAT sensor options
Old Jan 29, 2014 | 05:08 PM
ROOSTER.'s Avatar
Default IAT sensor options
i would like to relocate my intake air temp sensor and use a better sensor all together. i found a gm style sensor here:
GM Open Element IAT Sensor with 6" Pigtail by DIYAutoTune : Amazon.com : Automotive GM Open Element IAT Sensor with 6" Pigtail by DIYAutoTune : Amazon.com : Automotive
i'm looking into others also of course but i'm totally open to input from others.
thank you
Old Jan 29, 2014 | 05:32 PM
Turbo-LS's Avatar
Default Re: IAT sensor options
You can't use any other temp sensor other than Honda if you expect it to work correctly. If you love the sensor to the charge pipe just before the throtttlebody it will work just fine. That's how I have mine setup and it reads actual
Intake temps not heat soaked manifold temps. It also reacts faster than normal being it's not heats soaked. Also the ecu doesn't need a super fast reacting intake temp sensor. It's not that dependent on intake temps
Old Jan 29, 2014 | 05:46 PM
ROOSTER.'s Avatar
well if that's the case i guess i'll order a new o.e. i suppose. the one i have now is brittle and the stem is dark brown.
Old Jan 29, 2014 | 06:16 PM
MRGRIM's Avatar
R.I.P. Mark
the dark brown is just stain from Oil vapour
and a faster IAT is no use to a stock ECU
although you can benefit from modding it if your FI and use a Hondata S300
Old Jan 29, 2014 | 06:23 PM
ROOSTER.'s Avatar
yes it's on a boosted motor, but i will be using neptune. i think it might be cracked so either way it's getting replaced
Old Jan 29, 2014 | 10:34 PM
wantboost's Avatar
Who is Mr Robot?
Honda ecus can only use stock IAT sensors as already mentioned.
you can modify the IAT sensor to eliminate heat soak issues that come from the thermocouple being covered in multiple layers of plastic and rubber (I've done it to a few OEM sensors, have to be careful not to damage the thermocouple junction or the leads to it, very easy to break them) which will make it respond in milliseconds (compared to how slow the stock sensor is) but there's a limit to how fast the stock ecu, chipped or not, can process information
Old Jan 30, 2014 | 02:31 AM
KevinEF7's Avatar
Get an IAT sensor from a B20 motor, uses a standard metric thread (I believe m12X1.5) you can simply weld a nut on your charge piping, or simply tap your charge piping if you have not paper thin piping, and place it near the t/b
Old Jan 30, 2014 | 05:14 AM
ls joker's Avatar
Loved
xenocron iat kit, then install it on the charge piping before the throttle as mentioned above
Old Jan 30, 2014 | 06:35 PM
ROOSTER.'s Avatar
i've already looked into that flange, it's aluminum (same as evans tuning) my piping in steal.
Old Jan 30, 2014 | 06:38 PM
KevinEF7's Avatar
Like I said, there is a threaded iat sensor on b20's and some late 90s accord i forget off the top of my head, it uses a simple m12X1.5 threaded hole, in which case you can simply grab a nut from the hardware store and weld it to your steel pipe, exactly as I did
Old Jan 30, 2014 | 06:43 PM
ROOSTER.'s Avatar
this sounds more like an answer i was looking for. and yes to the previous posts, im aware they get heat soaked, thats the whole idea of relocating the sensor.
i'll pm for details kevin. thank you for your help
Old Jan 30, 2014 | 07:09 PM
92cxturbo's Avatar
Thats exactly what I did as well
Old Jan 30, 2014 | 07:13 PM
ROOSTER.'s Avatar
we are talking about a cr-v b20 correct ?
Old Jan 31, 2014 | 04:38 AM
lsturbo33's Avatar
I have steel 2 bolt style iat relocation flanges on hand. They come with new bolts also. If you need one pm me.
Old Jan 31, 2014 | 06:13 AM
ROOSTER.'s Avatar
i will keep that in mind. thank you
Old Jan 31, 2014 | 10:59 AM
92cxturbo's Avatar
Correct
Old Jan 31, 2014 | 11:01 AM
92cxturbo's Avatar
How do you mount a steel flange to an aluminum charge pipe?
Old Jan 31, 2014 | 11:09 AM
kyden's Avatar
He mentioned his charge pipe is steel.
Old Jan 31, 2014 | 12:11 PM
92cxturbo's Avatar
Ah, reading owns me.
Old Jan 31, 2014 | 12:20 PM
wantboost's Avatar
Who is Mr Robot?
moving it doesn't change the fact that the sensor body is what heatsoaks
Old Jan 31, 2014 | 05:42 PM
ROOSTER.'s Avatar
yes of course thats true but i still would rather move it away from a heatsourse.
ACTION JACTION
Engine Management and Tuning
May 17, 2011 03:48 PM
castle1313
Feb 4, 2010 03:56 PM
98vtec
Jun 5, 2008 09:50 PM
SixguN
Mar 4, 2005 11:34 AM
MikeSarr_GSR
Apr 14, 2003 11:48 AM
