help?? sohc turbo p08
Old Feb 10, 2014 | 07:17 PM
awaludinyuli's Avatar
Default help?? sohc turbo p08
the best safety compresion for d16 turbo daily driven (1 bar boost, T25, P08 head, low comp pistons)
..now i'm running 7 for compresion, i think there is to low,...
Old Feb 10, 2014 | 07:32 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: help?? sohc turbo p08
7 is stupidly low. "Safe" is all relative to who is tuning the car for you.
Old Feb 10, 2014 | 07:50 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
How does your motor even make power with a compression of 7?
Old Feb 10, 2014 | 08:02 PM
NotARaCist's Avatar
The motor doesn't - that tiny little T25 is making up for how painfully low his compression is.
OP, the whole point of lowering compression is to raise boost and make more power. Running 1 BAR through a T25 with THAT MUCH of a compression drop is...painful. You could get a LOT more power out of it running more boost.
Get it back to the stock 9.2:1. If you run forged internals, get it up around 10:1. If you don't want to rebuild your motor again, raise your boost. Let your tuner up the boost as far as he says is safe.
92civtegra
Aug 15, 2007 08:26 PM
ivebenjamin
Feb 2, 2006 11:34 PM
deemack79
Feb 14, 2005 05:33 PM
ej1 pilot
Jun 18, 2004 03:35 PM
mrblur
Oct 23, 2002 12:46 PM
