K series coil pack boost limitations on b series
Old 12-21-2013, 12:35 PM
Chuji's Avatar
Icon2 K series coil pack boost limitations on b series
I am looking to install k series coil packs and an AEM EPM on a 450whp boosted b series running AEM EMS Series 1. Will the stock RSX coil packs deliver reliable spark at this power range or do I need to run the AEM Twin Fire ignition module as well? What power range can stock RSX coil packs support?
Old 12-21-2013, 03:49 PM
turbohatch96y7's Avatar
Default Re: K series coil pack boost limitations on b series
I will be running this setup soon and I think each coil can handle 200hp. Not exactly sure but I know with the k series 3 wire smart coil they don't need a twin fire like the aem 2 wire dumb coil
Old 12-21-2013, 04:50 PM
MikeySpec's Avatar
I've seen as much as 800+whp(dynojet) and 38psi on stock coils with no other amps or coil drivers. Iridiums at the right heat range and gapped well usually does the job for me. Same results on AEM and Hondata.
Old 12-21-2013, 05:06 PM
Chuji's Avatar
Sounds good to me, time to get rid of the junk b series distributor setup. I seriously have a bucket of broken distributors/parts I've collected throughout the years. Thanks for the info guys.
Old 12-21-2013, 05:08 PM
Moderator in Chief
Muckman's Avatar
450hp is nothing for k coils.
Old 12-21-2013, 05:29 PM
Is the aem epm the only way to get rid of the dizzy bedsides the t1 setup?
Old 12-21-2013, 05:48 PM
Chuji's Avatar
Where can I buy the harness plug for each coil pack? Does anyone have a wiring diagram for the coil pack -> epm -> ems?
Old 12-21-2013, 06:02 PM
h2.4's Avatar
You can go into the AEM forums and get the wiring diagram and tooth counts for setup rising and falling edge data.
tepid1's Avatar
I know a few guys making 300hp+ per cylinder on these coil packs.
xxjonxx4
Engine Management and Tuning
09-25-2012 03:36 PM
xxjonxx4
09-08-2012 02:08 PM
JoHA
10-04-2008 06:07 PM
spunky424
11-02-2004 07:44 PM
Quick Reply: K series coil pack boost limitations on b series
