b18a1 build help
Old Dec 11, 2013 | 02:33 PM
rouchka12's Avatar
Default b18a1 build help
ok im going to be picking up a b18a1 from a guy that bought a machine shop it was in the back room when he got it. i want to build it for boost it is a fresh block with a block guard has h beam rods not sure type of pistons has clutch flywheel crank. getting it for $400. my goal is 400hp will the block be ok around that hp?
Old Dec 11, 2013 | 02:54 PM
meandmy's Avatar
Default Re: b18a1 build help
I do believe that you should make good power. If you're wanting the 400hp mark, the parts you use on the rest of the build are going to have to be all reputable parts.
Old Dec 11, 2013 | 03:39 PM
dantamparacer's Avatar
depending on the bore size, yes. Stock sleeves are typically good to the 500hp neighbor hood.
Old Dec 11, 2013 | 03:46 PM
rouchka12's Avatar
ok im not going to go cheep on this i want it to last
Old Dec 11, 2013 | 05:03 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
You'll need to find out what pistons and rods it has. No point to throw money at it when you don't know what's inside it.
Old Dec 11, 2013 | 06:05 PM
rouchka12's Avatar
i know h beam rods getting more details tomorrow
TravisBiggie
May 25, 2012 05:04 AM
BoostedxEk
Jun 15, 2009 09:23 AM
ge_itr
Jan 8, 2007 09:37 AM
honda1ne
Apr 7, 2004 10:49 AM
Bspec18
May 25, 2003 11:08 PM
