is this a good build
Old Dec 27, 2013 | 12:42 PM
Sgtschif's Avatar
Default is this a good build
Hi I'm a noob and this is first time building an engine. My power goal is 450fwhp. Any info would help.
Build:
Gsr block( stock sleeves 81.5mm bore)
LS crank( balanced and micro polished)
LS Manley H-beams
Supertech 9:1 cr pistons.
Cosmetic head gasket
ARP head studs
Arp main studs
ACL race bearings
Gsr girdle.
Stock gsr head
Stock TB
Edelbrock IM
Hobdata S300 w/tune.( still have to find a tuner. I'm in army so I'm kinda of new to the Tx area.)
Are my power goals capable,and what turbo kit should I get( no eBay junk)
Thanks for the help
Sincerely,
NOOB!!!
Old Dec 27, 2013 | 02:16 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Re: is this a good build
Engine looks good, you just need to research on a turbo kit
Old Dec 27, 2013 | 03:03 PM
Garage 808 Hatch's Avatar
I'd use a Honda HG, not Cometic. And any decent kit with a decent sized turbo will get you there. 30r, 5858, 6262,etc. Hit up SpeedFactory for a custom kit and they can suggest turbo sizes etc. Also dont forget the need for an upgraded fuel system, map sensor, etc to reach your goals
Old Dec 27, 2013 | 05:39 PM
Sgtschif's Avatar
Thanks guys
Old Dec 28, 2013 | 05:06 AM
Balor_Gr's Avatar
Sleeved block stock head?
I wound DEFINATELY do retainers.
Get some supertech valve spring / steel retainer set.I highly recccomend this upgrade.
A broken retainer may destroy everything(and 20 year old retainers destroyed many engines...)
If you are tight on the budget leave the IM stock.
Also i would use oem headgasket too.
Old Dec 28, 2013 | 06:30 AM
E_F_9's Avatar
Stock sleeves
Old Dec 28, 2013 | 10:02 AM
Sgtschif's Avatar
Yes, stock sleeves
Old Dec 28, 2013 | 10:05 AM
Balor_Gr's Avatar
Well **** i wanted to write "forged"
Mleighton203
Mar 25, 2016 06:39 PM
nealnanoHX
Apr 28, 2012 05:14 PM
TealCivic115
Oct 2, 2011 09:03 AM
RACEPAK
Oct 19, 2005 08:56 AM
