D16Y8 Build - New Rods/Pistons - Crankshaft Balance?
Old 12-31-2013, 10:50 AM
CplNet's Avatar
Default D16Y8 Build - New Rods/Pistons - Crankshaft Balance?
Im thinking about rebuilding my y8 and replace the stock piston/rods with eagle h-rods and forged 4032 pistons..
One issue i wonder now is: if i am changing the rod/piston, the weight/bobweight will change right? So i need the crankshaft to be balanced?
I dont remember anyone saying anything about this when building d-series but it shouldn`t be an obligatory step ?
Thankz
Old 12-31-2013, 11:00 AM
CplNet's Avatar
Default Re: D16Y8 Build - New Rods/Pistons - Crankshaft Balance?
Researching a little more..
OEM P2P (Y8) PISTON + PIN + ROD = 715g (215~220g for the piston)
EAGLE ROD H-BEAM D16 W/ ARP2000 = 530g
SUPERTECH P4-HD755-N21 PISTON = 220G + 71G (PIN)
So oem = 715g and eagle+supertech=821g.. that is a problem right?
I can try to use a I-Beam rod to lower the weight and fix this problem?
Old 12-31-2013, 11:04 AM
Moderator in Chief
Muckman's Avatar
No, its all balanced independently.
Old 12-31-2013, 11:05 AM
CplNet's Avatar
If i put new piston/rods i dont need to be balanced?
I asked because was reading this article:
http://www.carcraft.com/howto/ccrp_0...g/viewall.html
Old 12-31-2013, 11:09 AM
Moderator in Chief
Muckman's Avatar
The crankshaft should always be balanced if you intend to rev higher than stock. But adding heavier pistons/rods doesn't make it "out of balance" because you have equally heavy piston/rods traveling in the opposite direction. Its not about weight, its about balance (and harmonics).
Old 12-31-2013, 11:10 AM
CplNet's Avatar
Ahhh, got it muckman!! Of course lol. hehe thankz
And i dont plan to pass 7000rpm i fear the y8 oil issues
Old 01-04-2014, 11:09 AM
CplNet's Avatar
One question last question...
When i need to micropolish and when i need to balance the crankshaft? In which situation?
(i dont trust brazillian machine shops)
Lil Tones
02-11-2011 02:45 PM
2muchboost2blow
08-10-2010 06:23 PM
redsolturbo
08-07-2008 02:36 PM
jetlude
01-18-2008 04:43 AM
Quick Reply: D16Y8 Build - New Rods/Pistons - Crankshaft Balance?
