b16 tb intercooler coupler
Old Jan 22, 2014 | 03:26 PM
Mjalaly's Avatar
Default b16 tb intercooler coupler
So I am trying to find a coupler to mate up the 2.5 intercooler piping to the tb and nothing seems to fit. I tried a 2.5 coupler on the tb and it wouldn't fit and a 2.75 seems too loose. What size are you guys using? The od on the tb measures 2.6ish.
Old Jan 22, 2014 | 03:53 PM
carlos8's Avatar
Default Re: b16 tb intercooler coupler
On stock B series throttle use 2.5" coupler.
This is 2.5"
https://honda-tech.com/attachment.ph...1&d=1390438374
Old Jan 22, 2014 | 06:06 PM
TravisBiggie's Avatar
use your muscles...
Old Jan 22, 2014 | 06:20 PM
Mjalaly's Avatar
Maybe I just need to heat the hell out of it first.
Old Jan 23, 2014 | 05:38 AM
Schister66's Avatar
Man U FTW
The coupler on the TB is always a bitch...put a little windex on the inside of the coupler and it will slide over the TB a bit easier.
Old Jan 23, 2014 | 05:59 AM
SiRCiviC94's Avatar
I must have the perfect size it's like sliding on an intake
Old Jan 23, 2014 | 06:45 AM
Turbo-LS's Avatar
LOL I easily stretched a 2.5" into my 72mm TB no problem.
Old Jan 23, 2014 | 07:12 AM
rich7777's Avatar
Time to hit the gym OP.
Old Jan 23, 2014 | 07:28 AM
Mjalaly's Avatar
Yeah i was going to go with the "if it dont fit, dont force it" rule... but i guess not.
Old Jan 23, 2014 | 12:00 PM
wantboost's Avatar
Who is Mr Robot?
you have to stretch the 2.5 to fit. in this cold weather you'll have to *gently* heat the coupler or use some lube on the tb.
Old Jan 23, 2014 | 05:14 PM
TheToaster's Avatar
Use Lube. I like WD40 because it dries kinda Sticky.
Also, you can use a screwdriver to pry over.
Old Jan 24, 2014 | 04:07 AM
Schister66's Avatar
Man U FTW
Thats the same reason I always used windex...its slippery at first, but gets tacky/sticky when it dries.
I would be careful if you decide to use a screwdriver...its pretty easy, especially with a flathead screwdriver, to poke a hole in the coupler or tear it along the edge.
Old Jan 24, 2014 | 04:54 AM
Mjalaly's Avatar
Yeah i figured out this awesome way to not use screwdrivers when doing this kind of stuff... bike tire levers! Man... riding bikes for 20ys and i never made a connection.
CRXherbie91
Jul 28, 2010 04:48 PM
SCV_GSR
Dec 4, 2009 03:08 PM
pubestripe
Jan 8, 2005 03:32 PM
Sinner
Oct 13, 2003 11:30 AM
DIY_Racing
Dec 26, 2002 08:59 AM
