nos on itb's?
Old Feb 25, 2014 | 05:46 PM
tollickj's Avatar
Default nos on itb's?
Hey guys I'm in the process of building an all motor gsr and I bought obx 48mm itb's and curious if there's a way setting up nos with those and if its safe to use with my itb's. Anyone ever do this or know anything about this set up?
I got already: comp 2 cams, 48mm itb's,s eagle rods, skunk2 springs/retainers
Next on the list to get: 12.0:1 pistons (wiseco or cp), valves, lsd, nos kit maybe??
^^^^ To let you guys know where my plans are with the build.
Old Feb 25, 2014 | 05:48 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: nos on itb's?
OBX ITBs
There's nothing stopping you from running nitrous on ITBs. Same amount of plumbing as a properly setup wet kit.
Old Feb 25, 2014 | 05:56 PM
tollickj's Avatar
So what would be the safest route dry or wet shot? I've never done nos before so I'm just curious. How much of a shot would be safe too... I'm sorry if I'm asking silly "newbie" questions just wanna get the facts straight before I start investing into it.
Old Feb 25, 2014 | 05:57 PM
tollickj's Avatar
Originally Posted by NotARacist
OBX ITBs
appreciate the pic of the set up. ^^^
Old Feb 25, 2014 | 06:06 PM
NotARaCist's Avatar
From ZEX's FAQ's page:
Q: What is the difference between a “wet” nitrous kit and a “dry” nitrous kit?
A: A wet nitrous kit mixes nitrous and enrichment fuel by means of an injector nozzle that is mounted before the throttle body. This mixture is then drawn into the engine through the throttle body and intake manifold. A "dry" nitrous kit injects only nitrous with it´s injector while at the same time, increasing the engine´s fuel rail pressure to feed enrichment fuel through the engine´s own injectors.
From Nitrous Express's FAQ's page:
Q. What is the difference between a wet and a dry system?
A. A "Wet" system introduces a homogenous mixture of nitrous and atomized fuel into the incoming air stream, thus providing a perfect air/fuel ratio for each.
The picture I posted is a "wet" kit. I'm not a big spray-head, but I believe wet kits are considered better and safer, while dry kits are easier to install.
Old Feb 26, 2014 | 11:40 AM
wantboost's Avatar
Who is Mr Robot?
you're going to need a direct port setup, only way to make that work.
Old Feb 26, 2014 | 04:53 PM
tollickj's Avatar
I'm in the process of looking for one for my obx itb's.
Old Feb 26, 2014 | 05:24 PM
NotARaCist's Avatar
You won't find a "direct fit" kit - you'll have to do some fabrication.
Old Feb 26, 2014 | 05:36 PM
tollickj's Avatar
where did you find the tubes? Home depot or something?
Old Feb 26, 2014 | 05:56 PM
NotARaCist's Avatar
They're just basic flare lines and fittings The fittings that thread into the ITBs are separate pills though, you'll need to order them to match the size of the shot you want to run.
Any major company that sells nitrous, nitrous accessories, and nitrous kits should sell the hardware you'll need to make it work.
Old Feb 27, 2014 | 12:05 AM
wantboost's Avatar
Who is Mr Robot?
yea you can't make it work using stuff from home depot
I suggest you do a lot of research before you start dicking with anything
what are you using to tune the car?
Old Feb 27, 2014 | 01:26 PM
tollickj's Avatar
s300
Old Feb 28, 2014 | 06:08 PM
apexracer21's Avatar
Nos has a great direct port kit that goes underneath the injector so u dont have to drill anything and u can run a 100 shot safely. Also the kit comes with all the lines u need u just have to bend it to ur manifold and ur set up.
oianarchy
Dec 11, 2006 07:09 AM
Squirtin EGsr
Jan 17, 2006 06:25 AM
FD3S
Aug 17, 2002 08:09 AM
TypeR-R6
Aug 2, 2002 02:28 PM
