What my compression with these pistons? Turbo s2000
1 Post
I'm about to build my stroker 2.4 s2000 motor. I'll be useing a brand new Tsx k24 crank and inline pro f24 2.4 rods. For the pistons I bought the over sized 87.25 Mahle frm compatable -11cc dish pistons. These are the lowest compression pistons that they make. They are listed as 8.9:1 for the f20c and 9.6:1 for the f22c. But I'll be useing the k24 99mm crank. What do you think the compression will be for my setup? I'm guessing somewhere in the mid 10's?
Pics
Pics
Re: What my compression with these pistons? Turbo s2000
www.zealautowerks.com
input the custom information in the fields and select other in the fields to the left where the custom parts do not apply and that should give you your compression ratio. Put that crankshaft on its end or hang it by one end with the bolt. dont leave it laying down.
1 Post
Can someone tell me what the stock s2000 combustion chamber volume is? And the stock head gasket thickness and also the piston to deck height?
