y7 turbo.swap to z6 head or keep y7
So I'm about ready to build my y7 block but I'm not sure if I want to just keep my y7 head or if I really want to swap to a z6. HP goal is 350-400. if I can get away with just some springs, retainers and a regrind or even a stock cam in my y7 but still hit my goal efficiently then that would be sweet but I can pick up a z6 head pretty cheap and there is a lot more support for the z6. Haven't picked up the turbo yet but will probably be pte 5554. I do plan on going bigger sometime in the future. So if I can buy something once and be able to support bigger goals later I'd rather do that.
Should probably add build will be vitaras with Rc custom length rods. Swapping out crank for z6 one. acl race bearings.
Ported oil pump
arp head studs
y8 intake
grams 1000cc injectors
Pretty much got the block taken care of just need am opinion on head. Also this will be tuned on e85 so I still need to do some research on a fuel pump.any recommendations?
Ported oil pump
arp head studs
y8 intake
DO IT ON ALL FOURS
Re: y7 turbo.swap to z6 head or keep y7
Anything can be done but if you are planning on going more horsepower later then do all your upgrades now. Plus, just think of all the chicks you can pick up if you tell them you have VTEC y0!
stealthcivic94
12-12-2005 01:10 PM
