boost by gear
Old Jan 8, 2014 | 10:25 AM
prahaian's Avatar
Default boost by gear
I was wondering what was all involved in doing a boost by gear. I have a aem stand alone computer.
Old Jan 8, 2014 | 10:38 AM
Muckman's Avatar
Moderator in Chief
Default Re: boost by gear
You need a boost control solenoid which is sold by AEM.
And follow this tutorial:
Old Jan 8, 2014 | 11:28 AM
prahaian's Avatar
Thanks do you or anyone have a diagram on how to set it up. Do you put it in place of you manual boost controller?
Old Jan 8, 2014 | 11:34 AM
Muckman's Avatar
Moderator in Chief
This is the most common method to plumb your EBC.
This method will offer a nice boost range and good resolution. Minimum boost pressure will be slightly above wastegate spring pressure. Maximum boost pressure is usually 3-4 times wastegate spring (depending on back pressure).
ennah's Avatar
Yes you put the electronic boost solenoid in place of the manual solenoid.
Old Jan 8, 2014 | 11:38 AM
Muckman's Avatar
Moderator in Chief
If you want to replace the MBC with the same vac plumbing then you use this method:
This method will achieve a lower maximum pressure than the first method but the lowest pressure will be wastegate spring pressure. This method offers excellent control resolution and maximum pressure is usually 2-3 times wastegate spring.
Old Jan 8, 2014 | 11:46 AM
Muckman's Avatar
Moderator in Chief
And then we have the 4 port method which is the least popular but offers the widest boost range. Unfortunately the control resolution is not good. Minimum boost pressure is wastegate spring. Maximum boost pressure is 5-6 times wastegate spring (depending on back pressure)
builtboostedteg
Apr 5, 2006 05:19 PM
c61lude
Jan 19, 2006 04:34 PM
Sketch_hs
Aug 10, 2004 09:06 PM
SIK IN DA HED
Sep 13, 2001 03:16 AM
boostn5Ghaba
Jul 19, 2001 09:34 PM
